artrag Posted April 24, 2022 Share Posted April 24, 2022 I'm very rusty with the CP1600 asm, and I have a silly question. There is something stupid I'm doing and I cannot find. This routine is called with R0 aiming to an address in the video table and R2 aiming to a 4 word array I need to print a 2x2 block from R0 using the 4 word aimed by R2 I was trying to use the auto increment feature in MVI@ and MVO@ What is wrong in this code ? PRINT2X2: PROC MOVR R0,R4 MOVR R5,R3 MOVR R2,R5 MVI@ R5,R1 MVO@ R1,R4 MVI@ R5,R1 MVO@ R1,R4 ADDI #18,R4 MVI@ R5,R1 MVO@ R1,R4 MVI@ R5,R1 MVO@ R1,R4 MOVR R4,R0 MOVR R3,R5 JR R5 ENDP Quote Link to comment Share on other sites More sharing options...
Arnauld Posted April 24, 2022 Share Posted April 24, 2022 This code looks correct. What's going wrong? Note that you may want to save back the final value of R5 in R2 for consecutive calls (if that makes any sense) and you can just do JR R3 instead of MOVR R3,R5 / JR R5. 1 Quote Link to comment Share on other sites More sharing options...
artrag Posted April 24, 2022 Author Share Posted April 24, 2022 (edited) 3 minutes ago, Arnauld said: This code looks correct. What's going wrong? Note that you may want to save back the final value of R5 in R2 for consecutive calls (if that makes any sense) and you can just do JR R3 instead of MOVR R3,R5 / JR R5. Do you mean in R3 ? I.e. like this PRINT2X2: PROC MOVR R0,R4 MOVR R5,R3 MOVR R2,R5 MVI@ R5,R1 MVO@ R1,R4 MVI@ R5,R1 MVO@ R1,R4 ADDI #18,R4 MVI@ R5,R1 MVO@ R1,R4 MVI@ R5,R1 MVO@ R1,R4 MOVR R4,R0 JR R3 ENDP Edited April 24, 2022 by artrag Quote Link to comment Share on other sites More sharing options...
artrag Posted April 24, 2022 Author Share Posted April 24, 2022 Solved! The issue was outside this code, in the value of R2 Thanks! Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted April 24, 2022 Share Posted April 24, 2022 (edited) 33 minutes ago, artrag said: Do you mean in R3 ? I.e. like this PRINT2X2: PROC MOVR R0,R4 MOVR R5,R3 MOVR R2,R5 MVI@ R5,R1 MVO@ R1,R4 MVI@ R5,R1 MVO@ R1,R4 ADDI #18,R4 MVI@ R5,R1 MVO@ R1,R4 MVI@ R5,R1 MVO@ R1,R4 MOVR R4,R0 JR R3 ENDP Yes. You are not required to return with the same register. So if your return address was saved in R3, just JR from it like you have above. Pro Tip: For the record, R5 is merely a convention for return addresses. The only constraint is that the JSR instruction (Jump To Subroutine, which saves the return address then jumps) accepts only either R5 or R4 as the placeholder for the return value, but at some early time R5 was established as the de facto standard for the return address. Once the jump is made, there is nothing special about R5 (except that it holds the return address, of course). Returning from the subroutine is done with the JR (Jump To Register) which has no register restrictions, and is not even subroutine-specific. 29 minutes ago, artrag said: Solved! The issue was outside this code, in the value of R2 Thanks! Great! By the way, one thing to consider: MOVR and INCR both cost 6 CPU cycles, so copying a register in order to do a single auto-increment indirect copy results in a wash. Plus it has the downside of consuming R5 or R4. For example: MOVR R0,R4 ' 6 cycles MOVR R5,R3 ' <-- incidental cost of 6 cycles to save R5 contents MOVR R2,R5 ' 6 cycles MVI@ R5,R1 ' \_ copies & increments both R5 and R4 MVO@ R1,R4 ' / Saves 6 cycles for INCR per register MVI@ R5,R1 ' \_ copies and imcrements again MVO@ R1,R4 ' / Saves 6 cycles *if* you intend to use the final addresses again As illustrated, if you only increment R4 once, the 6 cycles you save from avoiding an INCR instruction are spent in copying the original value onto R4. Of course, there may be other reasons why you copy the original arguments, so this is just intended as a helpful general observation. dZ. Edited April 24, 2022 by DZ-Jay 1 Quote Link to comment Share on other sites More sharing options...
