Atari Flashback X Brazilian Variation
Hello everyone,
I have a question regarding the brazilian variation of Atari Flashback X, since its power output is not via a USB cable, not allowing to use the OTG cable method.
How can I upgrade this version easily, is there any SD support for this variation in its board?
Thanks in advance ;)
I heard there is no way to hack these units. I don't think it is possible to update the firmware on these units.
The only idea I have is to solder a USB connection to the PCB board and use some kind of rockchip tool to push an update onto the unit.
I do have one question, what firmware version number does your About Screen show? Later U.S. models with the reset hole on the bottom came with OTG support out of the box.
Found out, it’s AR3060B_v0.0.2
On 4/25/2022 at 5:58 PM, RenatoDCD said:
Hello everyone,
Tectoy put a sticker over the micro usb port... you can just remove it
if you disassemble it, you will see that the micro usb is still there, but with a workaround adapted to use in the 127v plug... if you prefer, you can remove this wire (and the sticker on the micro usb) and feed it with a power supply. cell phone power.
the good side of this brazilian version is that it can feed the energy and use the usb without needing the OTG in Y.
The bad side is that by converting 127v to 5v it heats up considerably.
Many many many THANKS!
I just removed the sticker and for a question to end this (at least up to the next question lol), no need for any other mod than just placing the OTG in the microUSB port, right? (I won’t mess in the electrical side since I’m stupid in this matter).
no hardware modification is needed, just insert the otg and follow with "unlock" with custom firmware.
on my part, "as a curious person", I noticed that this adaptation made by tectoy leaves the two data pins unused, I'm thinking of a way to put the usb stick on the inside using the data pins, leaving the micro usb port on the outside free.
  • 4 weeks later...
