EmOneGarand Posted April 26, 2022 Share Posted April 26, 2022 I've been fiddling with scaling at runtime but I can't seem to offset the origin so that its not scaling from (0,0) of the sprite but instead the center of the sprite rectangle. How is that done with the JagStudio API? Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted April 26, 2022 Share Posted April 26, 2022 21 minutes ago, EmOneGarand said: I've been fiddling with scaling at runtime but I can't seem to offset the origin so that its not scaling from (0,0) of the sprite but instead the center of the sprite rectangle. How is that done with the JagStudio API? The Jag doesn't scale sprites that way, you have to manually adjust the x/y position of the sprites depending on your scale. Quote Link to comment Share on other sites More sharing options...
