Morpheus23 Posted April 27, 2022 Share Posted April 27, 2022 I bought a German Atari Falcon. Aside from the power supply issue can I swap the TOS from the USA and make it work? Quote Link to comment Share on other sites More sharing options...
anzac Posted April 27, 2022 Share Posted April 27, 2022 The Falcon TOS is multilingual if it doesn’t keep the settings then you need to replace the NVRAM battery 1 Quote Link to comment Share on other sites More sharing options...
Morpheus23 Posted April 27, 2022 Author Share Posted April 27, 2022 Cool. Thanks. Quote Link to comment Share on other sites More sharing options...
Zogging Hell Posted April 28, 2022 Share Posted April 28, 2022 The keyboard layout will also be different, although you should be able to swap a US ST keyboard in there, it will be the wrong colour. Quote Link to comment Share on other sites More sharing options...
Tillek Posted April 29, 2022 Share Posted April 29, 2022 8 hours ago, Zogging Hell said: The keyboard layout will also be different, although you should be able to swap a US ST keyboard in there, it will be the wrong colour. Thanks for pointing that out.... because he probably wouldn't have noticed that the moment he looked at it. It's... almost... like the Germans speak a different language?????????? 1 Quote Link to comment Share on other sites More sharing options...
Zogging Hell Posted April 29, 2022 Share Posted April 29, 2022 8 hours ago, Tillek said: Thanks for pointing that out.... because he probably wouldn't have noticed that the moment he looked at it. It's... almost... like the Germans speak a different language?????????? Charming. What I perhaps should have pointed out is that if he changes the TOS language to English, he will either need to leave the German layout or swap the keyboard. Anyway, welcome to the block list! 1 Quote Link to comment Share on other sites More sharing options...
bfollowell Posted April 29, 2022 Share Posted April 29, 2022 2 hours ago, Zogging Hell said: Charming. What I perhaps should have pointed out is that if he changes the TOS language to English, he will either need to leave the German layout or swap the keyboard. Anyway, welcome to the block list! Yeah, he did ask "aside from", so he was obviously looking for differences. Don't worry about the snarky comment. It seems everyone is looking for a reason to be a jerk wad these days, and they jump at the first opportunity to seem funny and witty at someone else's expense. I mentioned the same thing in @Morpheus23's other thread when someone asked what a U.S. Falcon was. 1 Quote Link to comment Share on other sites More sharing options...
Morpheus23 Posted April 29, 2022 Author Share Posted April 29, 2022 Thanks for the feedback gents. I did take care of the keyboard already thru Best Electronics and I found a more efficient power supply. I posted a video 9 years ago of the Falcon I sold with the Cubase and Steinberg MIDI equipment. The video isn’t that good and there isn’t any audio of the audio gear. It was just to show prospective buyers that it worked. 1 Quote Link to comment Share on other sites More sharing options...
snarkdluG Posted April 29, 2022 Share Posted April 29, 2022 If it's a NTSC model it should have a 120V PSU (as OP mentioned) inside and the oscillator should be 32.215905 MHz (instead of 32.084988MHz for PAL). And the US layout on the keyboard as mentioned. TOS is multilingual so it doesn't need to be changed (also mentioned). Quote Link to comment Share on other sites More sharing options...
Zogging Hell Posted April 29, 2022 Share Posted April 29, 2022 (edited) 2 hours ago, Morpheus23 said: Thanks for the feedback gents. I did take care of the keyboard already thru Best Electronics and I found a more efficient power supply. Have Best still got Falcon keyboards in stock then? I really must try and wade through those catalogues more.. I have a Falcon with an ST keyboard swap, and always wanted to put it back to spec as the lighter colour doesn't seem quite right (although it is UK TOS set up at the moment, so that might be more tricky). Edited April 29, 2022 by Zogging Hell spelling Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted April 30, 2022 Share Posted April 30, 2022 On 4/29/2022 at 6:02 AM, Zogging Hell said: Charming. What I perhaps should have pointed out is that if he changes the TOS language to English, he will either need to leave the German layout or swap the keyboard. Anyway, welcome to the block list! Although it might not have come across as humor I'm sure Tillek was just trying to be funny. I've had the same problem in the forums, from time to time. I'd drop a line that I thought was blindingly funny only to have it go over like a lead balloon. Quote Link to comment Share on other sites More sharing options...
bfollowell Posted April 30, 2022 Share Posted April 30, 2022 4 hours ago, DarkLord said: Although it might not have come across as humor I'm sure Tillek was just trying to be funny. I've had the same problem in the forums, from time to time. I'd drop a line that I thought was blindingly funny only to have it go over like a lead balloon. Well, I'm certain that we've all been there at one time or another. When you miss tone and body language and have only the written, or in this case, typed word, a lot can go unheard. Quote Link to comment Share on other sites More sharing options...
Zogging Hell Posted April 30, 2022 Share Posted April 30, 2022 5 hours ago, DarkLord said: Although it might not have come across as humor I'm sure Tillek was just trying to be funny. I've had the same problem in the forums, from time to time. I'd drop a line that I thought was blindingly funny only to have it go over like a lead balloon. Well indeed, I'm sure I've done it on many an occassion as well and have may got the wrong end of the stick (and what I said originally wasn't perhaps the most well written bit of advice I've ever managed, he would have been quite right to haul me up on that without channelling the Jag forum) I'll unblock him, see how it rolls. Quote Link to comment Share on other sites More sharing options...
