Zoyx Posted May 9, 2022 Share Posted May 9, 2022 (edited) I blew away AtariOS and installed Win 11 Pro. Now I can't get into the BIOS. Hitting the ESC key doesn't work, although it briefly tells me that I hit the key. Del key doesn't do it. Also booting the system using a USB drive doesn't work. Anything else I can try? Edited May 9, 2022 by Zoyx Quote Link to comment Share on other sites More sharing options...
suspicious_milk Posted May 9, 2022 Share Posted May 9, 2022 (edited) "booting the system using a USB drive" ... I'm assuming you're talking about the recovery image burned to a USB thumb drive? If not - - try that. Seems an odd problem for sure. some older archived images https://archive.org/download/atari-vcs-2020-recovery-image rEFInd boot image, may be worth a shot https://sourceforge.net/projects/refind/files/0.12.0/refind-flashdrive-0.12.0.zip/download the official https://docs.google.com/document/d/17TeJMIZcLIsGMJEHlQAxOb_YdIuX4GoL4bvBExAudWU/edit#heading=h.2yj2qmj1e9go I think when I booted with a Linux Mint installer, it gave a "firmware" option in it's default GRUB menu (if nothing else works). Edited May 9, 2022 by suspicious_milk Quote Link to comment Share on other sites More sharing options...
Zoyx Posted May 9, 2022 Author Share Posted May 9, 2022 I've used the windows USB fob that I used to install Windows, won't boot to that anymore. I also have a USB drive with refind on it. Also no worky. I haven't tried an AtariOS recovery USB yet. Not interested in AtariOS but may try it to see if anything will work. Not holding my breathe. Quote Link to comment Share on other sites More sharing options...
suspicious_milk Posted May 9, 2022 Share Posted May 9, 2022 A quick google search revealed that some have had the same issue when using a keyboard plugged into the front USB (but worked fine when plugged into the rear). Worth a go. Quote Link to comment Share on other sites More sharing options...
Zoyx Posted May 9, 2022 Author Share Posted May 9, 2022 Windows took over access to the bios. I followed method #2 on this page and it worked. https://www.hp.com/us-en/shop/tech-takes/how-to-enter-bios-setup-windows-pcs 1 Quote Link to comment Share on other sites More sharing options...
