maeloterkim Posted May 15, 2022 Share Posted May 15, 2022 Hi all Can someone tell me how to find this analog 3d sensor joystick ? How to find this model? is a joystick from a vintage pong console Hanimex , Soundic , etc I tried to find in aliexpress and google for hours but i find only for ps2 ps3 ps4 etc The only text in the joystick is: 50K ohms B 100K ohms B Mk83K I need only the part with the potenciometers But I have not found anything like this Thanks Quote Link to comment Share on other sites More sharing options...
maeloterkim Posted May 16, 2022 Author Share Posted May 16, 2022 I have found a solution, in case it serves someone The full joystick, we will not find it unless we buy another complete console but that is not the ideal solution, since we always had a console that would not work The solution is to replace the part of the potentiometer that is wrong. That is, the bad part of the potentiometer and this part if we can "easily" find it in Aliexpress or elsewhere In this answer I have put photos of the part to replace There is a photo of the old part and another image of a new The joystick has two different potentiometers one of 50k and another of 100k What we must do is 1) Buy two different potentiometers of 50k and 100k where the part that we are going to disassemble, from the new potentiometers is as the part we will replace. More or less the same size with 3 pins 2) Disassemble the new parts and disassemble the old parts 3) Put the new parts in the Joystick and assemble it again. Keep in mind which potentiometer is 50k and which of 100k 4) Put the cables again and try This solution will surely also serve, other ancient joystiks from other consoles that we cannot find. Quote Link to comment Share on other sites More sharing options...
