VBXE blitter : transparency?
Hi, Back with another VBXE question... ? How can I do a blitter and use color 0 (black first of pallette #000000) as transparent?
I did some tweaking with the BLT_AND_MASK & BLT_XOR_MASK bytes in a blitblock (byte 16&17) but can't get something with color 0 to be transparent over the already drawed vram..
Thanks
Thanks
I suggest reading the Altirra Hardware reference manual or the VBXE manual… ?
I tried reading the VBXE manual about the AND/XOR mask, but that didn't explain a lot about it, especially for a 'not' that much programmer like I am... ? Probably I'm doing something wrong.. But I will check the Altirrra reference about it later ?
Edited by Thelen
There's also the VC (Video Control) register - bit 2 controls the "no-trans" register.  But the VBXE manual says that does not have an effect on the blitter (page 40).  I've only done some very simple blitter code in text & graphics modes, but just using mode0 for direct copying.
Nice to see someone else coding for VBXE - may I ask what you are doing currently?
21 hours ago, phaeron said:
Use blit mode 1 instead of mode 0 -- it skips source bytes that are $00 after the AND/XOR.
Thanks, that did it ?
Also thanks for that! Currently I'm making a Castlevania port, codename CastleAtaria ?.... For now the game scrolls and the player can walk, every week I make some progress. I don't know for how long I will work on it and can stay motivated enough ?
So far as it's programmed now I can use the code either for another sidescrolling game (like Super Mario or Ducktales where I also was doubting/thinking about to work on)- but like alway's there are a lot of ideas and too less time. I wanted also to easily design levels, so it can use output of the 'Tiled' software (and then convert that with a little Python code).
Just for the impression a little video...therandom pixels on top of the screen are there because there is nothing yet, it for the score etc.
  • Like 6
