MIKE5200 Posted June 5, 2022 Share Posted June 5, 2022 Hello I'm looking for the guy who was on here who made theses along time ago. Mine doesn't lock in when you press the cart down in the slot. Thanks Quote Link to comment Share on other sites More sharing options...
rayik Posted June 5, 2022 Share Posted June 5, 2022 is it one of these found here https://www.atarimax.com? Quote Link to comment Share on other sites More sharing options...
MIKE5200 Posted June 6, 2022 Author Share Posted June 6, 2022 2 hours ago, rayik said: is it one of these found here https://www.atarimax.com? Guess Avraham hasn't been on since 2006, So i hit a dead end Thanks Quote Link to comment Share on other sites More sharing options...
+Allan Posted June 10, 2022 Share Posted June 10, 2022 On 6/5/2022 at 1:00 PM, MIKE5200 said: Hello I'm looking for the guy who was on here who made theses along time ago. Mine doesn't lock in when you press the cart down in the slot. Thanks I still have mine. Did you try taking it out of the cartridge shell and try board with out it? You could try replacing the spring and the two parts that make up the door. They should be the same as any Atari brand cart. Quote Link to comment Share on other sites More sharing options...
+Allan Posted June 10, 2022 Share Posted June 10, 2022 On 6/5/2022 at 6:33 PM, rayik said: is it one of these found here https://www.atarimax.com? No, it is an earlier USB programmed cartridge made by someone else. Quote Link to comment Share on other sites More sharing options...
rayik Posted June 10, 2022 Share Posted June 10, 2022 If it does not lock in, could be a cartridge shell problem rather than pct one. Can you post pics of the cart including the bottom of it Quote Link to comment Share on other sites More sharing options...
MIKE5200 Posted June 10, 2022 Author Share Posted June 10, 2022 17 hours ago, Allan said: I still have mine. Did you try taking it out of the cartridge shell and try board with out it? You could try replacing the spring and the two parts that make up the door. They should be the same as any Atari brand cart. Didn't try it because of the white warrenty sticker. I did get it to work..My guess is the springs are shot of heavy use. Thanks Quote Link to comment Share on other sites More sharing options...
