stefan_sts Posted June 16, 2022 Share Posted June 16, 2022 Hi there , may could anyone explain which lines i have to cut to shut down the ex. mod. 1 still connected to the coleco ( pal )? I like to install a switch directly to the module , so i am able to start the coleco without disconnecting the vcs module every time , but i am still confused . Cut the 5V ( pin 58 --> pin 5,6 ) , the 12V ( pin 57 -->pin 7 ) and the reset line ( pin 13 --> pin1 ) , but coleco is still waiting for something ( black screen ) , -5v is obviuosly not connected on both sides of the pal version (pin 58,59 --> pin 2,3 ), same to the clock ( pin 45 --> pin 9 ) . At the moment the lines are ( as you can see ) reestablished and module works ordinary like always . Thy for any kind of help ! Greetings Quote Link to comment Share on other sites More sharing options...
rietveld Posted June 16, 2022 Share Posted June 16, 2022 (edited) Did you try breaking the ground connection at pin 1 and 2. The Colecovision / Adam should not see the expansion 1 without the ground Edited June 16, 2022 by rietveld Quote Link to comment Share on other sites More sharing options...
rietveld Posted June 16, 2022 Share Posted June 16, 2022 1 hour ago, rietveld said: Did you try breaking the ground connection at pin 1 and 2. Quote Link to comment Share on other sites More sharing options...
allansim Posted June 16, 2022 Share Posted June 16, 2022 I don't know the answer but I want to say this is a good idea. Quote Link to comment Share on other sites More sharing options...
stefan_sts Posted June 17, 2022 Author Share Posted June 17, 2022 Unbelievable ... but true , even this option doesn´t work ! As you can see i disabled the ground , and after an unsuccessful trial i moreover opened all the former clipped off lines too ( 5v , 12 v , reset line ) with the same result , colecovision still waits for something ( black screen ) . So in the end i reestablished another time all the cut lines ( now including the two ground lines ) and the exp. module 1 is working like it should have to . But it was worthy to attempt this idea , many thx and greetings ! Quote Link to comment Share on other sites More sharing options...
stefan_sts Posted June 20, 2022 Author Share Posted June 20, 2022 On 6/17/2022 at 1:47 PM, stefan_sts said: Unbelievable ... but true , even this option doesn´t work ! As you can see i disabled the ground , and after an unsuccessful trial i moreover opened all the former clipped off lines too ( 5v , 12 v , reset line ) with the same result , colecovision still waits for something ... may christmas , train , rent ... i don't know ( black screen ) . ( -5V and the clock is not connected to a pal board ) So in the end i reestablished another time all the cut lines ( now including the two ground lines ) and the exp. module 1 is working like ordinary . But it was worthy to attempt this idea , many thx and greetings ! Quote Link to comment Share on other sites More sharing options...
OGHUGO Posted August 30 Share Posted August 30 Hello, I was attempting to do the very same thing. To have the expanded module 1 attached at all times and be able to turn it off/on whenever I wanted to use it. I had to sever a few pins from the expansion port and add a SPDT switch that would turn off the power to the module to cut it out completely. The Red squares are the ones I severed, the yellow is +5v which needs to be cut and put on a switch, as well as the blue, which is +12 which needs to be cut and put on a switch. I can put up a video of the unit working if anyone is interested. Thanks. 1 Quote Link to comment Share on other sites More sharing options...
+5-11under Posted August 30 Share Posted August 30 Does that match this: Quote Link to comment Share on other sites More sharing options...
OGHUGO Posted August 31 Share Posted August 31 20 hours ago, 5-11under said: Does that match this: Did not see this, this mod is only on the vcs module 1, so nothing will be done to the colecovision. I also messed with pin 25 of the coleco tying to make it do something but i was not able to make it work. I proved it and when the expansion module was not on it was high (+5v) and when the expansion module was on it was low (gnd) so I put in a switch to make it high when the expansion module was on and still did not work. When I send +5v to pin 25, I was still getting the module and not colecovision. I had to sever the pins on the module itself to make this work. Quote Link to comment Share on other sites More sharing options...
NIAD Posted September 2 Share Posted September 2 (edited) This looks like a project for someone with the hardware skills to make an Expansion Module (PCB and case) that connects between the ColecoVision or ADAM's Expansion Interface and the Expansion Module #1 Atari Adapter to allow the EM#1 to stay connected at all times even when one wants to use ColecoVision/ADAM warez. This way nothing has to be modded on the original hardware. Edited September 2 by NIAD 1 Quote Link to comment Share on other sites More sharing options...
stefan_sts Posted September 7 Author Share Posted September 7 On 9/2/2023 at 11:59 PM, NIAD said: This looks like a project for someone with the hardware skills to make an Expansion Module (PCB and case) that connects between the ColecoVision or ADAM's Expansion Interface and the Expansion Module #1 Atari Adapter to allow the EM#1 to stay connected at all times even when one wants to use ColecoVision/ADAM warez. This way nothing has to be modded on the original hardware. Hi there , of course you are right in most of the cases , but the Colecovision needs some rework anyway after all these years to use it properly . I got some serious problems with the power switch , a defective controller chip and had some overheating ram chips ( on both available Colecos ) . So in the end you have to open the case , otherwise they won´t work anymore 😞 I am not an expert particular on Colecovision , but they are a beloved part of a colection of Retro Consoles and Computers ! Sorry for the bad quality of the pic , but the second one is from a video i made some time ago . Greetings Quote Link to comment Share on other sites More sharing options...
stefan_sts Posted September 7 Author Share Posted September 7 On 8/30/2023 at 9:46 PM, OGHUGO said: Hello, I was attempting to do the very same thing. To have the expanded module 1 attached at all times and be able to turn it off/on whenever I wanted to use it. I had to sever a few pins from the expansion port and add a SPDT switch that would turn off the power to the module to cut it out completely. The Red squares are the ones I severed, the yellow is +5v which needs to be cut and put on a switch, as well as the blue, which is +12 which needs to be cut and put on a switch. I can put up a video of the unit working if anyone is interested. Thanks. Amazing ! So you cut the red ones totally ? ( The pic shows some regular tracks on the reds ) Quote Link to comment Share on other sites More sharing options...
OGHUGO Posted September 19 Share Posted September 19 On 9/7/2023 at 6:04 AM, stefan_sts said: Amazing ! So you cut the red ones totally ? ( The pic shows some regular tracks on the reds ) So I made a short of how this works, but I noticed that I am still seeing the Colecovision screen in the background when I flip this on and off. Quote Link to comment Share on other sites More sharing options...
+Yurkie Posted September 21 Share Posted September 21 On 9/2/2023 at 5:59 PM, NIAD said: This looks like a project for someone with the hardware skills to make an Expansion Module (PCB and case) that connects between the ColecoVision or ADAM's Expansion Interface and the Expansion Module #1 Atari Adapter to allow the EM#1 to stay connected at all times even when one wants to use ColecoVision/ADAM warez. This way nothing has to be modded on the original hardware. Well said. I would make a pcb if I had free time anymore. I was thinking it could be a pcb shaped so that an external switch could be slide by cutting a small slot in the case. Quote Link to comment Share on other sites More sharing options...
+5-11under Posted September 21 Share Posted September 21 On 9/19/2023 at 11:54 AM, OGHUGO said: So I made a short of how this works, but I noticed that I am still seeing the Colecovision screen in the background when I flip this on and off. Does what you did match what I did? Quote Link to comment Share on other sites More sharing options...
OGHUGO Posted September 22 Share Posted September 22 On 9/21/2023 at 3:31 PM, 5-11under said: Does what you did match what I did? Not really, I only disconnected the points that I have on the picture I posted, I now had to put a halt / audio switch to halt the coleco and switch audio from the module one instead of the colecovision.. so there has to be 2 switches, one on the colecovision itself and one on the module one. Here is another video, with this halt switch I don't get the bad sound and no colecovision screen on the background of the atari game when I am playing it.. Now I am looking on a way to do s-video from the colecovision but cannot find how to do that. Quote Link to comment Share on other sites More sharing options...
