Shift838 Posted June 22, 2022 Share Posted June 22, 2022 (edited) So I know there are these 15kHz unicorn VGA LCD monitors out there. I recently found one. With the monitors that support 15kHz then to hook up the Geneve it should be fairly simple to wire one up with just a cable. I have not attempted to hook it up to the Geneve yet. I am curious if anyone has done this with other VGA 15kHz supported LCD's. My question, is that I believe that since the Geneve only has CSync that this signal would go to pin #13 (HSYNC) on the VGA connector. Can anyone verify? Edited June 22, 2022 by Shift838 Quote Link to comment Share on other sites More sharing options...
Tursi Posted June 23, 2022 Share Posted June 23, 2022 I can't verify your question, since that depends on the monitor (some monitors accept composite sync on HSync, some need it on green, some can't deal with it at all and need it separated). But I have used a number of 15Khz LCD monitors on my Amiga and Atari ST directly. 3 Quote Link to comment Share on other sites More sharing options...
Shift838 Posted June 27, 2022 Author Share Posted June 27, 2022 On 6/23/2022 at 1:00 AM, Tursi said: I can't verify your question, since that depends on the monitor (some monitors accept composite sync on HSync, some need it on green, some can't deal with it at all and need it separated). But I have used a number of 15Khz LCD monitors on my Amiga and Atari ST directly. I may have to use a sync stripper, good thing I have quite of few of them on hand just in case. Quote Link to comment Share on other sites More sharing options...
+mizapf Posted June 27, 2022 Share Posted June 27, 2022 I'm using a TV set but I connected the Geneve via the SCART input, not VGA. Quote Link to comment Share on other sites More sharing options...
