More weird stuff
42bs
I have an algo which I prototyped in Processing and ported to GPU.
Below three pictures are the same algo. Weird: VJ looks more or less identical, but running on real HW looks completely different?
Processing:
VirtualJaguar
The real thing (TM):
Processing:
VirtualJaguar
Q1: What does input to the algorithm look like?
Q2: What is algorithm supposed to do?
Q3: The slanted horizontal(ish) line (below numbers) in The Real Thing is just an optical illusion created by snapping photo of tv/monitor at an angle, correct?
It is going to be a new demo for Sillyventure, so I will not disclose yet much.
So much: The algo creates this image by doing simple adds, subs and shifts.
Regarding Q3, it is not optical illusion, the picture generated on the Jaguar really looks completely different and has this horizontal line.
25 minutes ago, Zerosquare said:
Have you double-checked that all memory is initialized?
Yes. I even changed it from zeroing to some other value.
Normally I use the blitter to clear memory, so switched to 68k loop.
Last what I did not yet check is, to remove the IRQ code from GPU and move OBL update back to the 68k.
This code behaves differently on VJ than on HW:
	add	x,tmp0
	add	y,tmp1
	and	mask,tmp0
	and	mask,tmp1
	add	map_base,tmp0
	shlq	#10,tmp1
	add	tmp0,tmp1
	jump	(LR)
	loadb	(tmp1),r0
This subroutine is called about 200k times but only one call makes the problems where tmp0 and tmp1 are both zero?!
mask is 1023, x/y range from 0 to 1023+delta.
Ok, again a pipeline/score board issue :(
Original code:
	moveq	#0,tmp0
	moveq	#0,tmp1
	BL	(GET_H)
	move	r1,ptr0
	move	step,r0
GET_H is above subroutine which read r0. But only once in the loop, r0 is not used, GET_H is only used to get the pointer into tmp1/r1.
The following "move step,r0" ends _before_ the "loadb" and therefore r0 gets overwritten by the memory contents (which is 0).
I really should make MACROs for load which just writes the loaded value to some dummy register.
Edited by 42bs
  • Like 4
  • 3 weeks later...
Maybe also change the coding style? Cyclomatic complexity is evil, even though branches seem to be cheap on JRISC. Immutable variables are best. We have 64 registers on the Jag. So it should be possible not to reuse them too often. Anyway, no I learned: SRAM seems to be fast, but it is not guaranteed to. So better try to cram everything into registers and sadly reuse them or even pack data.
  • Confused 4
