lbaeza Posted July 17, 2022 Share Posted July 17, 2022 Hi there, I have put online the "Exploring the Atari Frontier" by Alan J. Zett series of articles as published on SoftSide magazine back in 1982-83: https://lbaeza.neocities.org/frontier/index.html Please take a look and let me know your comments and corrections. Kind regards, Luis. 5 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted July 17, 2022 Share Posted July 17, 2022 In the GTIA section listing 4, some code is missing:- Line 20 has a GOSUB 90, but there is no line 90 from the looks of it lines 80, 90, 100 and 110 are missing. 20 Z=PEEK(704):POKE 77,0:IF Z<>255 THEN POKE 764,255:GOSUB 90 30 IF STRIG(0)=0 THEN 200 40 XP=XP+XD(STICK(0)):YP=YP+YD(STICK(0)):IF XP<0 THEN XP=79 50 IF XP>79 THEN XP=0 60 IF YP>160 THEN YP=0 70 IF YPCMAX THEN C=CMIN 120 IF B>BMAX THEN B=BMIN Quote Link to comment Share on other sites More sharing options...
lbaeza Posted July 17, 2022 Author Share Posted July 17, 2022 1 hour ago, TGB1718 said: In the GTIA section listing 4, some code is missing:- Line 20 has a GOSUB 90, but there is no line 90 from the looks of it lines 80, 90, 100 and 110 are missing. 20 Z=PEEK(704):POKE 77,0:IF Z<>255 THEN POKE 764,255:GOSUB 90 30 IF STRIG(0)=0 THEN 200 40 XP=XP+XD(STICK(0)):YP=YP+YD(STICK(0)):IF XP<0 THEN XP=79 50 IF XP>79 THEN XP=0 60 IF YP>160 THEN YP=0 70 IF YPCMAX THEN C=CMIN 120 IF B>BMAX THEN B=BMIN Thanks for pointing that out, I will go ahead and correct, hopefully during the day. Kind regards, Luis. Quote Link to comment Share on other sites More sharing options...
dmsc Posted July 17, 2022 Share Posted July 17, 2022 2 hours ago, TGB1718 said: In the GTIA section listing 4, some code is missing:- Line 20 has a GOSUB 90, but there is no line 90 from the looks of it lines 80, 90, 100 and 110 are missing. 20 Z=PEEK(704):POKE 77,0:IF Z<>255 THEN POKE 764,255:GOSUB 90 30 IF STRIG(0)=0 THEN 200 40 XP=XP+XD(STICK(0)):YP=YP+YD(STICK(0)):IF XP<0 THEN XP=79 50 IF XP>79 THEN XP=0 60 IF YP>160 THEN YP=0 70 IF YPCMAX THEN C=CMIN 120 IF B>BMAX THEN B=BMIN This is the image from internet archive: Seems the mising lines are: 80 COLOR ABS(C-CMAX):PLOT XP,YP:COLOR C:PLOT XP,YP:6OTO 20 90 IF Z=6 THEN 140 100 IF Z=35 THEN GRAPHICS O:B=BMIN:C=CMIN:GOTO 330 110 OB=B:OB1=B+1:OC=C:B=B+2:C=C+1:IF C>CMAX THEN C=CMIN Have Fun! Quote Link to comment Share on other sites More sharing options...
lbaeza Posted July 17, 2022 Author Share Posted July 17, 2022 2 hours ago, TGB1718 said: In the GTIA section listing 4, some code is missing:- Line 20 has a GOSUB 90, but there is no line 90 from the looks of it lines 80, 90, 100 and 110 are missing. 20 Z=PEEK(704):POKE 77,0:IF Z<>255 THEN POKE 764,255:GOSUB 90 30 IF STRIG(0)=0 THEN 200 40 XP=XP+XD(STICK(0)):YP=YP+YD(STICK(0)):IF XP<0 THEN XP=79 50 IF XP>79 THEN XP=0 60 IF YP>160 THEN YP=0 70 IF YPCMAX THEN C=CMIN 120 IF B>BMAX THEN B=BMIN These are fixed now, the culprit was a bad escaped <, so I changed that to < Kind regards, Luis. 1 Quote Link to comment Share on other sites More sharing options...
+Allan Posted July 17, 2022 Share Posted July 17, 2022 There are three errors in the listing in the article: Part 1, as published on Issue 41, Vol. 6 No. 8, June 1983. If you copy the listings and paste them into BASIC in an emulator, you can test the listings in all the articles easily. Quote Link to comment Share on other sites More sharing options...
lbaeza Posted July 20, 2022 Author Share Posted July 20, 2022 Hi Allan, thanks for the hint, I am already doing that. Now I need a hand debugging listing 4 here: https://lbaeza.neocities.org/frontier/frontier_10.html I have double-checked that listing and compared it with the source as printed on the magazine (Issue 44, Vol. 6 No. 11, September 1983), but all I get is a message saying "PMG$ ISN'T A LEGAL VARIABLE". Can you please check? Thanks in advance, Luis. 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted July 20, 2022 Share Posted July 20, 2022 I've had a quick look, it's messing about with the variable name table, bit of a pain to follow what it's up to. It is changing values in the variable value table The only thing I could see is PMG$ is DIM'd to 1 but in the code it's using 1024 bytes in the array, but as it's playing with the value table, maybe it's done there ? 700 DIM PMG$(1),VAR$(4):VAR$="PMG$" 940 PMG$=CHR$(0):PMG$(1024)=CHR$(0) Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted July 20, 2022 Share Posted July 20, 2022 Got it, typo line 870: 870 IF AZ2-128*(AZ2>27)=ASC(VAR$(AZ)) THEN VNTP=VNTP+1:NEXT AZ:GOTO 910 should be 870 IF AZ2-128*(AZ2>127)=ASC(VAR$(AZ)) THEN VNTP=VNTP+1:NEXT AZ:GOTO 910 2 Quote Link to comment Share on other sites More sharing options...
FifthPlayer Posted July 21, 2022 Share Posted July 21, 2022 (edited) 10 hours ago, TGB1718 said: I've had a quick look, it's messing about with the variable name table, bit of a pain to follow what it's up to. It is changing values in the variable value table The only thing I could see is PMG$ is DIM'd to 1 but in the code it's using 1024 bytes in the array, but as it's playing with the value table, maybe it's done there ? 700 DIM PMG$(1),VAR$(4):VAR$="PMG$" 940 PMG$=CHR$(0):PMG$(1024)=CHR$(0) This is a common hack used in BASIC programs to animate Player/Missile graphics. The program dimensions a 1 character string. It then manipulates the program's variable table to (1) move the memory address of the string to a 1K page boundary suitable for use as PM memory and (2) extend the length to 1024 bytes. Atari BASIC string assignments are used to quickly move the PM sprites vertically. BASIC string manipulation is just an assembly language memory copy, which is just what you'd do to move the sprites in an assembly program. Edited July 21, 2022 by FifthPlayer 2 Quote Link to comment Share on other sites More sharing options...
lbaeza Posted July 24, 2022 Author Share Posted July 24, 2022 (edited) On 7/20/2022 at 1:45 PM, TGB1718 said: Got it, typo line 870: 870 IF AZ2-128*(AZ2>27)=ASC(VAR$(AZ)) THEN VNTP=VNTP+1:NEXT AZ:GOTO 910 should be 870 IF AZ2-128*(AZ2>127)=ASC(VAR$(AZ)) THEN VNTP=VNTP+1:NEXT AZ:GOTO 910 Thanks TGB1718, I have corrected the typo and found another error on line 950, but this has already been fixed too... Now demo on Listing 4 works! Kind regards, Luis. Edited July 24, 2022 by lbaeza typ0 1 Quote Link to comment Share on other sites More sharing options...
Gury Posted July 30, 2022 Share Posted July 30, 2022 In magazine issue 39 (Vol. 6 No. 6, March 1983, article GTIA Part 1), there is small glitch in Doodle program, line 330: 330 GRAPHICS 0:? CHR$(125);"ENTER GRAPHICS MODE(9,10,11)';:INPUT M Fixed: 330 GRAPHICS 0:? CHR$(125);"ENTER GRAPHICS MODE(9,10,11)";:INPUT M Wrong program line will result in improper functioning: the program will not ask you for GTIA graphics mode. Quote Link to comment Share on other sites More sharing options...
Gury Posted August 10, 2022 Share Posted August 10, 2022 The article source code listings are now referenced here. If there are any errors, let me know. Quote Link to comment Share on other sites More sharing options...
Gury Posted August 11, 2022 Share Posted August 11, 2022 (edited) _________ Edited August 11, 2022 by Gury Quote Link to comment Share on other sites More sharing options...
