+grafixbmp Posted July 19, 2022 Share Posted July 19, 2022 Slight dilemma. If I'm using an indirect pointer with the Y index and I need to offset the pointer because the Y index isn't inline with the true pointer, then does the page value just wrap itself to do this or does the high byte need to be adjusted too. Technically, no page boundary access would occur. Ex: data to be accessed is located on any arbitrary page of the 4k rom space starting at 00 to say 0B. This is 12 bytes worth. Likewise, the pointer in ram would have 00 be the start (or end) with whatever page the hi byte is as the 2 byte pointer. Providing the y index is exclusively set to index this data, everything would work as normal. However, if the Y index is decrementing from 30, then the pointer would need to be offset before hand so that the data reads correctly. It would stop before going below the pages 00 address so as not to access data across a page boundary. So does the 2 byte pointer only need the low byte changed or both the high byte and low to compensate this? Sorry if the explanation is overly complicated. I don't want to incurr any extra cycles. Quote Link to comment Share on other sites More sharing options...
alex_79 Posted July 19, 2022 Share Posted July 19, 2022 8 hours ago, grafixbmp said: ... does the page value just wrap itself to do this or does the high byte need to be adjusted too. Indexed addressing isn't confined to a page (it doesn't wrap around). You must necessarily change also the high byte, and you'll get a 1 cycle penality because of page crossing when the Y index is added to the base address. e.g. Suppose the data table is at the beginning of the rom ($f000-$f00b). If you access it using indirect,Y addressing, with Y ranging from 30 to 19 ($1e to $13), the pointer would need to point to address $efed. To avoid the extra cycle, move the data table away from the beginning of the page so that you don't get page crossing. In the example above, make it start at least from address $f013, so the pointer points to the same page of the final address. 2 Quote Link to comment Share on other sites More sharing options...
