ultima Posted July 26, 2022 Share Posted July 26, 2022 So I typed up Andrew Davies sample kernel and after insulting my anti-virus and some typo errors of my own I got it to compile. Well it runs as shown in the document using z26 no problem, in Stella I got this as the result: did I need to set some defaults for it to display correctly? Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted July 26, 2022 Share Posted July 26, 2022 If you entered this, then add CLEAN_START Reset CLEAN_START StartOfFrame When the 2600 is powered on RAM and TIA will be in a random state. CLEAN_START is a macro that will zero out RAM and TIA. You can view the code for CLEAN_START in macro.h. The lines you're seeing are random bit patterns in the players, missiles, ball, and/or playfield. I think back in 2003 Stella would init everything to zero, but now it'll randomize RAM and TIA if Developer Settings is turned on: And since you are developing leave that turned on as it'll expose bugs that'll occur on some, but not all, 2600s. 3 Quote Link to comment Share on other sites More sharing options...
ultima Posted July 26, 2022 Author Share Posted July 26, 2022 Thanks that did the trick. 1 Quote Link to comment Share on other sites More sharing options...
