ST-ranger Posted August 1, 2022 Share Posted August 1, 2022 Greetings all. Cleaning out my Megafile (dust & etc. build-up for years!) and noticed a glaring Tantalum in the upper left corner. Have had terrible times with these in old PCs so figured I'd replace it. Only problem is - what is the value? Is this the only Tantalum one has to pay attention to in the drive? Thanks Quote Link to comment Share on other sites More sharing options...
ST-ranger Posted August 1, 2022 Author Share Posted August 1, 2022 Forgot to mention - it's a Megafile 30. Have looked all through the schematics here: https://ia800203.us.archive.org/2/items/Atari_Megafile_30_60_Service_Manual_RLL_undated/Atari_Megafile_30__60_Service_Manual_RLL_undated.pdf And unable to find a C27. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted August 1, 2022 Share Posted August 1, 2022 (edited) The value should be written on the side, unfortunately I can't make out it's value from the photo, as you say, it's a tantalum bead type should have a voltage rating and capacitance in uFarads Update: I don't think that's the right circuit diagram for your drive, in the photo U3 is a 40 pin chip on the circuit diagram U3 is a 74LS51 which is a 14 pins AND/OR gate Edited August 1, 2022 by TGB1718 Quote Link to comment Share on other sites More sharing options...
ST-ranger Posted August 1, 2022 Author Share Posted August 1, 2022 5 hours ago, TGB1718 said: The value should be written on the side, unfortunately I can't make out it's value from the photo, as you say, it's a tantalum bead type should have a voltage rating and capacitance in uFarads Update: I don't think that's the right circuit diagram for your drive, in the photo U3 is a 40 pin chip on the circuit diagram U3 is a 74LS51 which is a 14 pins AND/OR gate Thanks! Should have quoted it - the value on the side simply says "106L" or "I06L". Is this enough to positively identify it? How curious with the circuit diagram. On the motherboard is printed: SH205 C100169 REV.5 Reading up, it looks as if this is the 20MB circuit board. Found the schematic for it, which in fact has a C27, but can't really read it (55uf???): https://ia600206.us.archive.org/26/items/Atari_SH205_Schematic_1987/Atari_SH205_Schematic_1987.pdf Quote Link to comment Share on other sites More sharing options...
snarkdluG Posted August 1, 2022 Share Posted August 1, 2022 106L would be 10uF and that corresponds to the schematics. You can also see the other components besides C27 on the schematics and on the board (CR3, CR6, R8, R19). Quote Link to comment Share on other sites More sharing options...
ST-ranger Posted August 1, 2022 Author Share Posted August 1, 2022 36 minutes ago, snarkdluG said: 106L would be 10uF and that corresponds to the schematics. You can also see the other components besides C27 on the schematics and on the board (CR3, CR6, R8, R19). Thank you! I was looking at the C27 above it. How many Volts should it be? 106 = 10uF 6v? 16v? Quote Link to comment Share on other sites More sharing options...
snarkdluG Posted August 2, 2022 Share Posted August 2, 2022 10 hours ago, ST-ranger said: Thank you! I was looking at the C27 above it. How many Volts should it be? 106 = 10uF 6v? 16v? The first two digits on the number is the value in pico farads. Then the third one is the multiplier. So 10x1000000. I don't really know if L stands for voltage ratings or tolerance. If it's tolerance it should correspond to 15% but in that case it's a bit odd that voltage ratings is not labeled. I would just go with higher voltage rating. Like 35V or 25V. Anything above 10-16V is fine. It doesn't matter really as long as the rating on the capacitor is larger then the voltage supplied on the rail. When I did a search on google it comes up as 35V. Quote Link to comment Share on other sites More sharing options...
ST-ranger Posted August 4, 2022 Author Share Posted August 4, 2022 On 8/2/2022 at 7:40 PM, snarkdluG said: The first two digits on the number is the value in pico farads. Then the third one is the multiplier. So 10x1000000. I don't really know if L stands for voltage ratings or tolerance. If it's tolerance it should correspond to 15% but in that case it's a bit odd that voltage ratings is not labeled. I would just go with higher voltage rating. Like 35V or 25V. Anything above 10-16V is fine. It doesn't matter really as long as the rating on the capacitor is larger then the voltage supplied on the rail. When I did a search on google it comes up as 35V. Thanks. Ended up putting in a 10uF 50v. Upon boot now, the HDD sounds healthy and am less worried about tantalum-related issues. However, I can't remember - does one require HDX Utils disk to be in the drive? The HDD doesn't mount on the desktop. Downloaded the hdx504 disk but it doesn't contain any autoboot folders or anything. Quote Link to comment Share on other sites More sharing options...
