JagMod Posted August 3, 2022 Share Posted August 3, 2022 I was reading the online Reference Manual and came across several misspellings... JagStudio supports BASIC, C and Assember languages. <---Assember should be Assembler JagStudio supports BASIC, C and Assembler languages. Old RB+ Commands and their new Jagstudio equivelants <---equivelants should be equivalents Old RB+ Commands and their new Jagstudio equivalents The conversion tool will recognise these and convert them to the format required. <---recognise should be recognize The conversion tool will recognize these and convert them to the format required. jsfLoadClut(palette_address,target_clut_number_of_indices) <---missing a comma jsfLoadClut(palette_address,target_clut, number_of_indices) If you wish to use the angle lookup, you MUST call this function to initialise it. <---initialise should be initialize If you wish to use the angle lookup, you MUST call this function to initialize it. Print text at location rapLocate and allow concatination. <---concatination should be concatenation Print text at location rapLocate and allow concatenation. There are 8 sprites to sort and the highest Y values will be futher back in the z-order. <---futher should be further There are 8 sprites to sort and the highest Y values will be further back in the z-order. Rename the two occurances of RUPDALL_FLAG to jsfVsyncFlag <---occurances should be occurrences Rename the two occurrences of RUPDALL_FLAG to jsfVsyncFlag 'color' is misspelled everywhere, but I'll let that one slide! 1 Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted August 3, 2022 Share Posted August 3, 2022 Thanks we will update some of those - appreciate the checking! however: JagStudio is maintained by a Brit and an Aussie. Get used to seeing S instead of Z, and there is a U in colour you barbarian 3 Quote Link to comment Share on other sites More sharing options...
tbs123456 Posted August 3, 2022 Share Posted August 3, 2022 (edited) 5 minutes ago, CyranoJ said: Thanks we will update some of those - appreciate the checking! however: JagStudio is maintained by a Brit and an Aussie. Get used to seeing S instead of Z, and there is a U in colour you barbarian Edited August 3, 2022 by tbs123456 3 Quote Link to comment Share on other sites More sharing options...
tbs123456 Posted August 3, 2022 Share Posted August 3, 2022 Oops, posted wrong pic. Was supposed to have the f-bomb crossed out and I can't get rid of it. Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted August 3, 2022 Share Posted August 3, 2022 18 minutes ago, tbs123456 said: Oops, posted wrong pic. Was supposed to have the f-bomb crossed out and I can't get rid of it. I think we can handle it. Need to think of a command needing aluminium now, thanks! 2 Quote Link to comment Share on other sites More sharing options...
JagMod Posted August 3, 2022 Author Share Posted August 3, 2022 2 hours ago, CyranoJ said: Thanks we will update some of those - appreciate the checking! however: JagStudio is maintained by a Brit and an Aussie. Get used to seeing S instead of Z, and there is a U in colour you barbarian I figured as much about the s/z thing. I posted mainly because of the incorrect jsfLoadClut() prototype. 1 Quote Link to comment Share on other sites More sharing options...
Sporadic Posted August 3, 2022 Share Posted August 3, 2022 7 hours ago, JagMod said: I was reading the online Reference Manual and came across several misspellings... JagStudio supports BASIC, C and Assember languages. <---Assember should be Assembler JagStudio supports BASIC, C and Assembler languages. Old RB+ Commands and their new Jagstudio equivelants <---equivelants should be equivalents Old RB+ Commands and their new Jagstudio equivalents The conversion tool will recognise these and convert them to the format required. <---recognise should be recognize The conversion tool will recognize these and convert them to the format required. jsfLoadClut(palette_address,target_clut_number_of_indices) <---missing a comma jsfLoadClut(palette_address,target_clut, number_of_indices) If you wish to use the angle lookup, you MUST call this function to initialise it. <---initialise should be initialize If you wish to use the angle lookup, you MUST call this function to initialize it. Print text at location rapLocate and allow concatination. <---concatination should be concatenation Print text at location rapLocate and allow concatenation. There are 8 sprites to sort and the highest Y values will be futher back in the z-order. <---futher should be further There are 8 sprites to sort and the highest Y values will be further back in the z-order. Rename the two occurances of RUPDALL_FLAG to jsfVsyncFlag <---occurances should be occurrences Rename the two occurrences of RUPDALL_FLAG to jsfVsyncFlag 'color' is misspelled everywhere, but I'll let that one slide! Thanks for these, I have updated them in the next release (excluding a couple that aren't typos ?) 1 Quote Link to comment Share on other sites More sharing options...
