ACML Posted August 22, 2022 Share Posted August 22, 2022 On 8/17/2022 at 8:21 PM, bob1200xl said: I think you can cure jailbars by leaving C60 in the board. Bob I think Bob may be addressing both? 1 Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted August 22, 2022 Author Share Posted August 22, 2022 1 hour ago, ACML said: I think Bob may be addressing both? More than likely. He knows the 1200XL that's for sure ! Quote Link to comment Share on other sites More sharing options...
+mytek Posted August 22, 2022 Share Posted August 22, 2022 @bob1200xl does the 100pf (C60) simply limit frequency response in the Luma amplifier that follows? If so I can definitely see how that would minimize jail bars which are a higher frequency effect, but wouldn't it also take the crispness out of the image, making text look soft and almost out of focus? Edit: on further thought 100pf isn't much, so whatever filtering occurred would be minimal. Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted August 29, 2022 Author Share Posted August 29, 2022 Got my Hercules Workshop Atari color video cable (composite video) - 800 XL XE (shielded) (6 foot) today. It definitely helped with the colour bleed through. The video in post No.1, all lines are now crisp (no bleeding) but the multi-colour remains. 3 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted August 29, 2022 Share Posted August 29, 2022 1 hour ago, Ricky Spanish said: Got my Hercules Workshop Atari color video cable (composite video) - 800 XL XE (shielded) (6 foot) today. It definitely helped with the colour bleed through. The video in post No.1, all lines are now crisp (no bleeding) but the multi-colour remains. If you're using composite video, the "multi-colour" issues will always be there. The only way to not have that is with s-video (or RGB). 1 Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted August 29, 2022 Author Share Posted August 29, 2022 Not a problem. It just an very specific scenarios where it draws single white lines. Everything else looks really good. 1 Quote Link to comment Share on other sites More sharing options...
ACML Posted September 25, 2022 Share Posted September 25, 2022 (edited) I finally had a chance to try returning the 100pf capacitor to C60 to see if the jailbars would be diminished. On my test, the presence of or absence of C60 does not see to show a difference wrt jailbars (see photos). This is without C60 installed (i.e. open) This is with a 100pf capacitor installed at C60 Don't know how good the pictures will show, but in realtime, I could not tell that the presence of C60 made any difference. The intensity of the jailbars appeared unchanged. You mileage may vary. Anyone else try this? And yes, I used the Hercules cable direct to an S-video monitor. Edited September 25, 2022 by ACML Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted September 25, 2022 Author Share Posted September 25, 2022 (edited) Looks much different than mine with Hercules composite cable. Haven't done the capacitor mod. (click on pic to zoom in) Looks way worse on a modern monitor. Edited September 25, 2022 by Ricky Spanish Quote Link to comment Share on other sites More sharing options...
ACML Posted September 25, 2022 Share Posted September 25, 2022 You are saying "composite". Have you tried using S-Video? The quality of a Y/C "separate" video is a much clearer and sharper image. Composite is basically like RF and usually disappointing. 1 Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted September 25, 2022 Author Share Posted September 25, 2022 2 minutes ago, ACML said: Have you tried using S-Video? Don't have or can find anything S-video other the my 60" plasma. But using that for my 1200 is out of the question. I generally have no complaints with the CRT other than some color bleeding. (see vid in post #1). Quote Link to comment Share on other sites More sharing options...
ACML Posted September 25, 2022 Share Posted September 25, 2022 For $32, you can buy a S-video to HDMI converter. https://www.amazon.com/SUNNATCH-Converter-S-Video-Composite-Upscale/dp/B08ZYKC47R/ref=sr_1_22_sspa?crid=3N40SWB6T58MU&keywords=etekcity+s-video+to+hdmi+converter&qid=1664133575&qu=eyJxc2MiOiIxLjM0IiwicXNhIjoiMC4wMCIsInFzcCI6IjAuMDAifQ%3D%3D&sprefix=etek+city+s-video+to+hdmi+converter%2Caps%2C77&sr=8-22-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyNE5PVkVOUEdWQ0tHJmVuY3J5cHRlZElkPUEwMjMwOTI3MVpKNjlWNEFYWlM0NyZlbmNyeXB0ZWRBZElkPUEwNDkxMDMyMU00VFNIUjkwNEs4NCZ3aWRnZXROYW1lPXNwX2J0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU= 1 Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted September 25, 2022 Author Share Posted September 25, 2022 (edited) Is that what you use with your above pic ? Mine compared to Altirra set to best video: Edited September 25, 2022 by Ricky Spanish Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted September 27, 2022 Author Share Posted September 27, 2022 Seems all the chips sit on sockets. Where to where does the chroma fix go ? Thanks ! Quote Link to comment Share on other sites More sharing options...
ACML Posted September 27, 2022 Share Posted September 27, 2022 The ClearPic2002 mod has the pickoff point for chroma "Add a wire from the junction of R27 and C61 to J2-5 (the empty pin on the video DIN connector)". I don't know if you have to complete the ClearPic2002 mod for this to be a good point. 1 Quote Link to comment Share on other sites More sharing options...
mimo Posted September 27, 2022 Share Posted September 27, 2022 On 9/25/2022 at 8:43 PM, Ricky Spanish said: Is that what you use with your above pic ? Mine compared to Altirra set to best video: From a composite signal I'd be happy with that! Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted September 27, 2022 Author Share Posted September 27, 2022 4 hours ago, mimo said: From a composite signal I'd be happy with that! Haha don't get me wrong, I am happy with it. But if I can fix that colour bleed I mean why not. 1 Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted September 28, 2022 Author Share Posted September 28, 2022 Guess its ain't bad. Some rainbow artifacts with composite video. 1 Quote Link to comment Share on other sites More sharing options...
CommodoreDecker Posted September 28, 2022 Share Posted September 28, 2022 On 8/15/2022 at 8:24 PM, Rybags said: It's NTSC artifacting caused by the hires video signal being interpreted as colour information when using RF or composite video input. You need to use S-video. 2 problems though - some devices actually combine it into composite which will still produce artifacting, and S-video is pretty dead as a standard and not included on TVs these days. I bought a s-video to HDMI convert off of Amazon for $40. Does a good job... it also does composite, but s-video is a lot sharper. I'm amazed composite lasted longer for new sets (though many models require an adapter cable going from 3.5mm 3-lead male connector to the individual composite/l-audio/r-audio female RCA jacks rather than direct connections... ) Quote Link to comment Share on other sites More sharing options...
CommodoreDecker Posted September 28, 2022 Share Posted September 28, 2022 On 9/25/2022 at 2:23 PM, ACML said: For $32, you can buy a S-video to HDMI converter. https://www.amazon.com/SUNNATCH-Converter-S-Video-Composite-Upscale/dp/B08ZYKC47R/ref=sr_1_22_sspa?crid=3N40SWB6T58MU&keywords=etekcity+s-video+to+hdmi+converter&qid=1664133575&qu=eyJxc2MiOiIxLjM0IiwicXNhIjoiMC4wMCIsInFzcCI6IjAuMDAifQ%3D%3D&sprefix=etek+city+s-video+to+hdmi+converter%2Caps%2C77&sr=8-22-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyNE5PVkVOUEdWQ0tHJmVuY3J5cHRlZElkPUEwMjMwOTI3MVpKNjlWNEFYWlM0NyZlbmNyeXB0ZWRBZElkPUEwNDkxMDMyMU00VFNIUjkwNEs4NCZ3aWRnZXROYW1lPXNwX2J0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU= Yup, that's the one. Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted September 28, 2022 Author Share Posted September 28, 2022 4 hours ago, CommodoreDecker said: I bought a s-video to HDMI convert off of Amazon for $40. Does a good job... Care to post a pic of the 'ready prompt' screen & the ram/rom screen in the self tester with your HDMI convertor ? I want to compare it to mine, thanks. Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted September 28, 2022 Author Share Posted September 28, 2022 So whats the simplest way to hook up chroma ? Thanks ! Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted September 29, 2022 Share Posted September 29, 2022 So whats the simplest way to hook up chroma ? Thanks.. See Acml's post above from Tuesday. Quote Link to comment Share on other sites More sharing options...
ACML Posted September 29, 2022 Share Posted September 29, 2022 (edited) 13 hours ago, Ricky Spanish said: So whats the simplest way to hook up chroma ? Thanks ! Here it is using the Clearpic2002 modification. Edited September 29, 2022 by ACML Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted September 29, 2022 Author Share Posted September 29, 2022 6 hours ago, ACML said: Here it is using the Clearpic2002 modification. So I just solder a wire between the two ? Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted September 29, 2022 Share Posted September 29, 2022 On 9/27/2022 at 4:28 AM, ACML said: The ClearPic2002 mod has the pickoff point for chroma "Add a wire from the junction of R27 and C61 to J2-5 (the empty pin on the video DIN connector)". I don't know if you have to complete the ClearPic2002 mod for this to be a good point. So as per above instruction. Acml's pic shows location of the r27 and c61. A wire from those to pin 5 of the din. Quote Link to comment Share on other sites More sharing options...
