Ecernosoft Posted August 18, 2022 Share Posted August 18, 2022 Hello! I'm very confused by Dodraw. Apparently it can draw sprites in 26 cycles and it can... if your sprite is a square that is! I can only get one line of my sprite to appear. What am I doing wrong? Kernal is: Count ldy #9 lda #12 dcp Ypos bcs dogrp0 lda #0 beq Nodraw dogrp0 lda (Where),y Nodraw sta GRP0 dex sta WSYNC bne Count Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted August 18, 2022 Share Posted August 18, 2022 Have you seen my tutorial? DoDraw is covered in Step 4, but I highly recommend you start at the beginning to better understand what's going on. I put lots of comments in the source code, so be sure to download and review the source as you go thru each Step of the tutorial. Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted August 18, 2022 Author Share Posted August 18, 2022 2 hours ago, SpiceWare said: Have you seen my tutorial? DoDraw is covered in Step 4, but I highly recommend you start at the beginning to better understand what's going on. I put lots of comments in the source code, so be sure to download and review the source as you go thru each Step of the tutorial. Thanks, you're the best! I'll go see it now. Quote Link to comment Share on other sites More sharing options...
