scottinNH Posted September 19, 2022 Share Posted September 19, 2022 (edited) What options are there to support internationalization in CC65? Let's say you find a text utility in Polish, and you want to update the codebase to also support English (or the reverse language flow). Has anyone seen an example/demo in C that handles this in any way? I'm guessing there's 2 ways to approach this. i) A codebase that selects which language to compile to, using #defines. ii) On Linux I've used GNU gettext(), but that approach immediately feels heavy (and in any case, it wouldn't automatically handle different character sets). Looking for a suggestion how this has been done, or a link to some code that does this. Cheers all. Edited September 19, 2022 by scottinNH Quote Link to comment Share on other sites More sharing options...
scottinNH Posted September 19, 2022 Author Share Posted September 19, 2022 Ohh this page has some neat ideas for resource constrained embedded devices: https://barrgroup.com/embedded-systems/how-to/firmware-internationalization (won't help with the character set though) Quote Link to comment Share on other sites More sharing options...
baktra Posted September 20, 2022 Share Posted September 20, 2022 The article has some good points. The character sets could be included by the means of ca65 which supports conditional assembly. 1 Quote Link to comment Share on other sites More sharing options...
damosan Posted September 20, 2022 Share Posted September 20, 2022 If I was going about trying to support internationalization, from a font perspective, I'd probably look at copying the OS to RAM and then overwriting the default OS font. You can also load your custom font into any 1k aligned memory region and tell the OS to go to that region for font data. The benefit of loading the OS into RAM is that you can basically overwrite any part of the OS you won't be needing. You'll need to practice some care here but there are significant chunks of RAM you can free up in this way (say the floating point routines, the international character set data in XL/XE machines, the cassette driver, etc.). In any event then I'd be able to deploy one binary with several 1k font files allowing the user to select their language at runtime (saving their selection for future runs). There are plenty of source code examples out there of loading custom fonts. 1 Quote Link to comment Share on other sites More sharing options...
scottinNH Posted September 22, 2022 Author Share Posted September 22, 2022 (edited) Is there an index of all the Atari OS ROMS, OR (better still) is there an index of all Atari character sets (in byte or some other format)? ...if I know "which" ROMs to extract character sets from, I should be able to, at least one to start. To put together a demo/example that switches between say Polish, and English + French, it looks like I'd need to: Download Eastern Europe ROM Extract character set somehow (the location will be the same, but I'll need to learn what tool is best for this) Embed this character set into the code, then make that character set active (I did this long ago in BASIC with a USR() machine function) Invoke localized print strings using that alternate character set This sounds very doable, and seems like it could be "switched between" either at compile time (#defines) or dynamically (costing 1K per character set) Going to try this as described above; if any blanks can be filled in that'd help. I need to pivot to another task but I'll be back with results. Edited September 22, 2022 by scottinNH Quote Link to comment Share on other sites More sharing options...
+David_P Posted September 22, 2022 Share Posted September 22, 2022 The XE and XL lines have two character sets built in, the second one containing European characters. Not available on the 400/800, though. Quote Link to comment Share on other sites More sharing options...
Mark2008 Posted September 22, 2022 Share Posted September 22, 2022 I think everyone has covered it. But, when I was still interested in Cyrillic, it was just a matter of re-defining the characters and using it. Half way down the page, some code on how that picture was done. basically loads a new font to memory to overwrite the one that came from rom - then understand that "#hfqdth" now means драйвер. for example. 1 Quote Link to comment Share on other sites More sharing options...
