TGB1718 Posted September 30, 2022 Share Posted September 30, 2022 (edited) I've been trying to use timers 3 , 4 & 5 and noticed something I wasn't expecting. Unlike timers 1 and 2, there is no vector to a routine, instead you set the counter value using SETVBV i.e. LDA #5 ; timer 5 ldy #0 ; timer countdown value hi ldx #50 ; timer countdown value lo jsr setvbv when the counter reaches zero, the timer 5 flag (normally 0) is set ($FF) and that works fine. But unlike timers 1 and 2 which stop counting down when they reach zero, timers 3, 4 and 5 keep counting. I would have expected them to stop at zero. The only way I have found to stop them is when the flag gets set is have a routine set x and y to zero and call SETVBV LDA #5 ; timer 5 ldy #0 ; timer countdown value hi ldx #0 ; timer countdown value lo jsr setvbv Not tried on real hardware yet, this was using Altirra emulating a 130XE EDIT: Just noticed timers 1 and 2 keep counting too, but they do set an interrupt and it gets actioned once until reset Edited September 30, 2022 by TGB1718 Quote Link to comment Share on other sites More sharing options...
Rybags Posted October 1, 2022 Share Posted October 1, 2022 They should stop counting once they hit 0000. The behaviour should be: When timer hasn't been used it's flag will be 00 and it's value will be 0000. When a timer is set, it's value becomes non-zero. The OS VBlank checks timer values and doesn't touch any timer with value of 0000. If the value is nonzero, the timer is decremented. The flag will then be set to FF if the timer is nonzero, flag will be set to 00 if the timer value hits 0000. So, the situation is the same for a never used timer and one that has reached 0000. So programatically you should just keep track of whether you're using a particular timer. And of course note that Timers 3-5 are maintained in deferred VBlank so not guaranteed to always be working. Timers 1-2 aren't interrupts, just indirect JSR. Quote Link to comment Share on other sites More sharing options...
phaeron Posted October 1, 2022 Share Posted October 1, 2022 What specific behavior are you seeing, are the CDTMV3-5 values actually underflowing below $0000 to $FFFF and counting down from there? In Altirra's debugger, you can watch these on screen (ww cdtmv3 / wb cdtmf3, and wc * to clear all). There is an apparent error that I know of in the Atari OS Manual's description of these timers. Appendix L, P8 says that the CDTMF3-5 flags are only modified by the OS during initialization or upon timeout, but every version of the Atari OS that I know of unconditionally sets these flags on every VBLANK that the associated counters are decremented. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted October 1, 2022 Author Share Posted October 1, 2022 Thanks for the info, I'll do some more checking with Altirra debug on (have to figure out how to use it again ) I was looking at the timer values and from what I could see is they continued counting after reaching zero, also once triggered, I could not get the flag to reset, I think because the timer was cycling through zero. I managed to achieve what I wanted, but feel it's a bit "cludgy" as I think the timer should stop once it reaches zero. Quote Link to comment Share on other sites More sharing options...
Rybags Posted October 1, 2022 Share Posted October 1, 2022 The OS code should be consistent among versions here and it's very clear - the counters do nothing if the value is 0000. Note of course each timer is a 2 byte value. Also note the flags are only maintained as part of the process of decrementing the timers. You shouldn't need to call SetVBV to set the timers to 0. Quote Link to comment Share on other sites More sharing options...
