Kenshi Posted October 10, 2022 Share Posted October 10, 2022 (edited) I just got an Atari 800XL a few weeks ago I've been messing with. One of the first things I did was learn EASMD and write a program that plays music and cycles rainbow colors on the screen. It was a bit of an adjustment from x86 but not too bad. Now I'm trying to to learn to write programs for it from my main computer since GUIs and multitasking are so helpful. I read that cc64/ca64 is pretty awesome plus it's in the apt repository (and I may want to try programming in C later), so that's what I'm using. It seems somewhat like gas, so it's a lot more familiar than EASMD, but I can't get the most basic program, a hello world program, to assemble and link. The assembler makes an object file no problem, but the linker is faulting out with this: $ ld65 -C atari-asm.cfg characters.o -o characters Unresolved external '__AUTOSTART__' referenced in: /usr/share/cc65/cfg/atari-asm.cfg(6) Unresolved external '__EXEHDR__' referenced in: /usr/share/cc65/cfg/atari-asm.cfg(5) ld65: Error: 2 unresolved external(s) found - cannot create output file The atari-asm.cfg file seemed like the best one to use when writing a program completely in assembly. The official documentation says I should define __AUTOSTART__ and __EXEHDR__ if I want to make a plain binary file, but I want a regular executable I can run from DOS, not a bin file. I can't find anything else about them. I tried writing a very simple program in C to compile it into assembly and maybe see what I need to do, but it didn't help. When I get to the linker stage, it faults out with the same messages. It does compile in one go with cl65, but I can't see what it's doing differently. Here's what I've written. .macpack atari .export _main SAVMSC = $0058 SDLSTL = $0230 blank8 = $70 lms = $40 jvb = $41 .bss .data hello: .byte "Ahoy there.\n" .code .proc _main: near ldy #0 loop: lda hello,y sta (SAVMSC),y iny cpy #12 bne loop rts .endproc Edited October 10, 2022 by Kenshi Fixed code tags Quote Link to comment Share on other sites More sharing options...
Kenshi Posted October 10, 2022 Author Share Posted October 10, 2022 I finally got it to assemble using cl65 instead of ca65 and ld65 and by linking in atari.lib. I thought cl65 was solely for C programs based on what I had read, but I decided to try it and eventually got just the right command to make it work. Quote Link to comment Share on other sites More sharing options...
baktra Posted October 10, 2022 Share Posted October 10, 2022 2 hours ago, Kenshi said: I finally got it to assemble using cl65 instead of ca65 and ld65 and by linking in atari.lib. I thought cl65 was solely for C programs based on what I had read, but I decided to try it and eventually got just the right command to make it work. Good that you solved. Without cl65, you would need to specify atari.lib in the command line for ld65. Quote Link to comment Share on other sites More sharing options...
Kenshi Posted October 10, 2022 Author Share Posted October 10, 2022 9 hours ago, baktra said: Good that you solved. Without cl65, you would need to specify atari.lib in the command line for ld65. I suspected that to be the case before I tried cl65, but when I did specify it, it just gave a bunch of other undefined references. $ ld65 -C atari-asm.cfg characters.o atari.lib -o characters ld65: Warning: Combined alignment for segment 'BSS' is suspiciously large (512). Last module requiring alignment was 'characters.o'. ld65: Warning: /usr/share/cc65/cfg/atari-asm.cfg(28): Segment 'BSS' isn't aligned properly; the resulting executable might not be functional. ld65: Warning: Cannot evaluate assertion in module 'atari/crt0.s', line 207 Unresolved external '__CONSTRUCTOR_COUNT__' referenced in: runtime/condes.s(30) Unresolved external '__CONSTRUCTOR_TABLE__' referenced in: runtime/condes.s(32) runtime/condes.s(33) Unresolved external '__DESTRUCTOR_COUNT__' referenced in: runtime/condes.s(47) Unresolved external '__DESTRUCTOR_TABLE__' referenced in: runtime/condes.s(49) runtime/condes.s(50) Unresolved external '__LOWCODE_RUN__' referenced in: atari/crt0.s(207) atari/crt0.s(207) Unresolved external '__LOWCODE_SIZE__' referenced in: atari/crt0.s(207) atari/crt0.s(207) Unresolved external '__RESERVED_MEMORY__' referenced in: atari/crt0.s(75) atari/crt0.s(79) ld65: Error: 7 unresolved external(s) found - cannot create output file It seems to work though if I use atari.cfg instead of atari-asm.cfg. I did try atari.cfg yesterday but it probably wasn't with atari.lib at the same time. The manual led me to believe atari-asm.cfg was the one to use for a project completely in assembly language, but it doesn't seem to be the case to me. Oh well. At least I can assemble some simple programs now and I can hopefully figure out the intricate details as I go along. Quote Link to comment Share on other sites More sharing options...
baktra Posted October 11, 2022 Share Posted October 11, 2022 It seems that the atari-asm.cfg is designed to be used without the runtime library. In that case, one must supply his own EXEHDR and AUTOSTRT segments. I will try what you've tried myself and compare the resulting binaries, this interests me. Quote Link to comment Share on other sites More sharing options...
