rockdoc2010 Posted October 10, 2022 Share Posted October 10, 2022 So I was dusting off a unit for sale and came upon a 1200 that has the alpha systems 256K memory upgrade installed. I am sure it is probably a Rambo knock-off and I don't care. My question is why the self test don't see more than 3 16K bars? Is There a basic peek that I can try to determine my memory? Thank You! Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted October 10, 2022 Share Posted October 10, 2022 Self test will only test stock memory, it has no knowledge of any expansion RAM. To test the extra RAM (if it's a RAMBO), you would need to POKE a value at $4000, PEEK PORTB and save it, POKE PORTB with a suitable value to enable an 8K windows at address $4000 to $7fff (bits 2 and 4 must be '0' and bit 1 must be 1) POKE a different value into $4000, PEEK the value back, make sure its the same value so you know it's RAM restore PORTB and PEEK $4000 and see the result you previously stored there. You can then do this for each bank I believe these values will work:- List of free banks (index=regvalue): 4=$E3 5=$E7 6=$EB 7=$EF 8=$C3 9=$C7 10=$CB 11=$CF 12=$A3 13=$A7 14=$AB 15=$AF 16=$83 17=$87 18=$8B 19=$8F Don't worry about the index number, for a 1200XL you can subtract 4, I got these values from a 130XE, so banks 0 to 3 are the extra memory in the 130XE. You just use the Hex numbers into PORTB Quote Link to comment Share on other sites More sharing options...
adam242 Posted October 11, 2022 Share Posted October 11, 2022 SimCheck is your friend. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted January 30, 2023 Share Posted January 30, 2023 XRAM, etc as well Quote Link to comment Share on other sites More sharing options...
