stushug Posted October 18, 2022 Author Share Posted October 18, 2022 43 minutes ago, Tillek said: You're good... Like BillC said, it has the built in R-Verter, so just make sure you use the R-Verter handler... (And I feel dumb forgetting about that because I bought a second SX212 just so I could take it apart and look at it while keeping the other one for use). And don't worry about asking questions... it's how we learn. Thanks. I'm not afraid to ask, it's just sometimes I get a bit confused. Must be getting too old!! Quote Link to comment Share on other sites More sharing options...
Tillek Posted October 18, 2022 Share Posted October 18, 2022 1 hour ago, stushug said: Thanks. I'm not afraid to ask, it's just sometimes I get a bit confused. Must be getting too old!! Yeah, I hear that... we're talking about underwater basket weaving, right? Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted October 18, 2022 Share Posted October 18, 2022 9 hours ago, Tillek said: Yes. There was a version of SX Express for it. Or you can use it as a standard RS232 with the right equipment (850/P:R:C) but the RS232 was probably more often used by the ST crowd. In fact, mine got used on both the ST and my 8-bit. Quote Link to comment Share on other sites More sharing options...
stushug Posted October 20, 2022 Author Share Posted October 20, 2022 (edited) I received my SX212 the other day, with a copy of BobTerm on a 5 1/4 disk. When I turn on the 800 Bobterm automatically loads, but it stops at the splash screen and I can't get any further(I attached a pic.) What am I missing? I have the modem daisychained through my XF551. The modem powers up and the correct lights are on according to the manual. I also have the BASIC cartridge installed. Is it needed? Edited October 20, 2022 by stushug Quote Link to comment Share on other sites More sharing options...
BillC Posted October 20, 2022 Share Posted October 20, 2022 1 hour ago, stushug said: I received my SX212 the other day, with a copy of BobTerm on a 5 1/4 disk. When I turn on the 800 Bobterm automatically loads, but it stops at the splash screen and I can't get any further(I attached a pic.) What am I missing? I have the modem daisychained through my XF551. The modem powers up and the correct lights are on according to the manual. I also have the BASIC cartridge installed. Is it needed? The SX212 has a built-in RVerter interface, Bobterm needs the proper driver loaded to work with it. The post linked below has an ATR with Bobterm 1.22 attached: Quote Link to comment Share on other sites More sharing options...
stushug Posted October 20, 2022 Author Share Posted October 20, 2022 (edited) I was just reading another thread about that, and The_Doctor had recommended v 1.22. I was searching for a copy when you posted! I'm not sure how to get it from my PC to a 5 1/4 floppy so I can run it though. Also, I just found my Telelink II cartridge. I think it came with my long lost 835 modem. Will Telelink work with the SX212? EDIT: I just tried my Telelink II cart with the SX212 modem. I got the opening screen you described in your linked post with the second option and telelink is behaving as you describe in option 2) starting with "Line Interface error" 1) Modem Good / Connected Atari Logo screen saying "Press Return to Continue". After pressing "Return": Pressing "3", Dial from keyboard, you would get the "Please Enter the Number" response. Enter a number and press "Return", screen will show Dialing... and you can hear the internal relay clicking... Light should display upon connecting... Pressing "6", Change Line Speed, you would get the speaker beep error. 2)Modem Bad / Not Connected Atari Logo screen saying "Line Interface Error" and maybe "Stored Information Lost". After pressing "Return": Pressing "3", Dial from keyboard, you would get the speaker beep error. Pressing "6", Change Line Speed, you can toggle 300/1200 Baud. I don't know if the modem is bad or not, not sure how to test it. Edited October 20, 2022 by stushug Quote Link to comment Share on other sites More sharing options...
manterola Posted October 20, 2022 Share Posted October 20, 2022 The easiest way I can think of is: First, make a copy of the bobterm floppy you have, just in case. Second, boot with a DOS floppy and then insert the bobterm copy you have and check if rverter.hnd or similar named file is already in your bobterm floppy. (use directory list, typically option A) If the rverter file is there, copy (typically option C) the rverter file to a new file named rs232.com ( for example in DOS 2.5 or 2.0 and Mydos Select option C and then type RVERTER.HND, RS232.COM) If the RS232.com already exist in the floppy directory you will need to delete that file first (typically option D) and then do the copy mentioned in the previous paragraph. After these steps, if you boot with the bobterm floppy, the bobterm program should be able to load the correct rs232.com (rverter.hnd), which is the correct handler (like a driver) for your sx212 modem. Quote Link to comment Share on other sites More sharing options...
+David_P Posted October 21, 2022 Share Posted October 21, 2022 BobTerm uses all RAM and does not use BASIC. Try booting without BASIC; the 8K it's occupying should be occupied by the program. 1 Quote Link to comment Share on other sites More sharing options...
stushug Posted October 21, 2022 Author Share Posted October 21, 2022 (edited) 18 hours ago, David_P said: BobTerm uses all RAM and does not use BASIC. Try booting without BASIC; the 8K it's occupying should be occupied by the program. I removed the basic cartridge and boot from the BobTerm disk and it worked. It's v1.23 though, and I read that it's a bit quirky with regular 800's. I was able to connect to a board ( i got the phone # from this forum but I can't remember the name. The # is 503-852-3170.) at 1200 but I got what seems to be a lot of random characters and it stops at the opening screen when your asked to choose which type board you want, numbered 1,2 and 3. Not matter which number I choose it stops there. I posted a picture for reference. At least I now know that the modem works and I was able to connect to something. Babysteps! Edited October 21, 2022 by stushug 1 Quote Link to comment Share on other sites More sharing options...
stushug Posted October 21, 2022 Author Share Posted October 21, 2022 On 10/17/2022 at 11:28 AM, Tillek said: http://www.sfhqbbs.org/ataribbslist.php He runs Alcatraz and the ForemXE BBS. What are the dialup numbers? I want to try to connect with my SX212 1 Quote Link to comment Share on other sites More sharing options...
Tillek Posted October 21, 2022 Share Posted October 21, 2022 @stushugFrom their dial in page... The access numbers Clark, WA: 564-244-26oo Vista, CA: 760-330-26oo New York City, NY: 929-470-26oo Saxapahaw, NC: 743-5oo-26oo Harlingen, TX: 956-3oo-26oo Des Moines, IA: 515-4oo-26oo Toll: 833-PLZ-DIAL PHATSTAR TELEPORTER 778-716-PHAT From there you'll be asked for a username/password that will connect you to the right BBS... Use column 2 for BOTH username AND password. The list at 2600.network is long (over 1000), so these are just the Atari ones here. moonlight_mile's BBSs are Alcatraz and Forem XE... BF2k's BBS is Boot Factory 2k and mine is STar Fleet HQ (it's an ST BBS, get it?) Alcatraz BBS alcatraz Amis XE amisxe Area 52 area52 *Bikerbob's Clubhouse bikerbobsclubhouse Boot Factory 2K bootfactory2k Cheeze Daddy's House of Funk cheezedaddyshouseoffunk *DarkForce! BBS darkforce! Forem XE BBS foremxe Hawaii BBS Atari 8 Bit hawaiiatari8bit Heisenberg's Hideout heisenbergshideout Mousenet mousenet NiteLite BBS nitelite Part-Time BBS parttime Southern Amis southernamis *St. Guild BBS st.guild *Star Fleet HQ starfleethq Edited to indicate ST boards that don't support ATASCII (with an *) (Thanks for the reminder BF2k+) Also, there is Basement BBS, but it has two listings, and I honestly don't remember which one it is. Basement BBS (1) basement1 Basement BBS (2) basement2 One of them will support ATASCII, the other is the wrong one. That said, Basement (the right one) also has it's own direct dial up number... 1-503-245-5416 1 Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted October 21, 2022 Share Posted October 21, 2022 1 hour ago, stushug said: I removed the basic cartridge and boot from the BobTerm disk and it worked. It's v1.23 though, and I read that it's a bit quirky with regular 800's. I was able to connect to a board ( i got the phone # from this forum but I can't remember the name. The # is 503-852-3170.) at 1200 but I got what seems to be a lot of random characters and it stops at the opening screen when your asked to choose which type board you want, numbered 1,2 and 3. Not matter which number I choose it stops there. I posted a picture for reference. At least I now know that the modem works and I was able to connect to something. Babysteps! The board you connected to is an ASCII connection.. You are in Atari mode. Change that. Quote Link to comment Share on other sites More sharing options...
Tillek Posted October 21, 2022 Share Posted October 21, 2022 Updated the list a bit..... Quote Link to comment Share on other sites More sharing options...
stushug Posted October 21, 2022 Author Share Posted October 21, 2022 1 hour ago, Tillek said: @stushugFrom their dial in page... The access numbers Clark, WA: 564-244-26oo Vista, CA: 760-330-26oo New York City, NY: 929-470-26oo Saxapahaw, NC: 743-5oo-26oo Harlingen, TX: 956-3oo-26oo Des Moines, IA: 515-4oo-26oo Toll: 833-PLZ-DIAL PHATSTAR TELEPORTER 778-716-PHAT From there you'll be asked for a username/password that will connect you to the right BBS... Use column 2 for BOTH username AND password. The list at 2600.network is long (over 1000), so these are just the Atari ones here. moonlight_mile's BBSs are Alcatraz and Forem XE... BF2k's BBS is Boot Factory 2k and mine is STar Fleet HQ (it's an ST BBS, get it?) Alcatraz BBS alcatraz Amis XE amisxe Area 52 area52 *Bikerbob's Clubhouse bikerbobsclubhouse Boot Factory 2K bootfactory2k Cheeze Daddy's House of Funk cheezedaddyshouseoffunk *DarkForce! BBS darkforce! Forem XE BBS foremxe Hawaii BBS Atari 8 Bit hawaiiatari8bit Heisenberg's Hideout heisenbergshideout Mousenet mousenet NiteLite BBS nitelite Part-Time BBS parttime Southern Amis southernamis *St. Guild BBS st.guild *Star Fleet HQ starfleethq Edited to indicate ST boards that don't support ATASCII (with an *) (Thanks for the reminder BF2k+) Also, there is Basement BBS, but it has two listings, and I honestly don't remember which one it is. Basement BBS (1) basement1 Basement BBS (2) basement2 One of them will support ATASCII, the other is the wrong one. That said, Basement (the right one) also has it's own direct dial up number... 1-503-245-5416 Wow! Thanks Tillek!!! Quote Link to comment Share on other sites More sharing options...
stushug Posted October 21, 2022 Author Share Posted October 21, 2022 1 hour ago, bf2k+ said: The board you connected to is an ASCII connection.. You are in Atari mode. Change that. Thank you sir. I've never used BobTerm before, now I have to learn the menus and choices. I can't go wrong with all the support I receive here though! Quote Link to comment Share on other sites More sharing options...
Tillek Posted October 21, 2022 Share Posted October 21, 2022 9 minutes ago, stushug said: Thank you sir. I've never used BobTerm before, now I have to learn the menus and choices. I can't go wrong with all the support I receive here though! Looking forward to seeing you around. Quote Link to comment Share on other sites More sharing options...
stushug Posted October 22, 2022 Author Share Posted October 22, 2022 4 hours ago, stushug said: I removed the basic cartridge and boot from the BobTerm disk and it worked. It's v1.23 though, and I read that it's a bit quirky with regular 800's. I was able to connect to a board ( i got the phone # from this forum but I can't remember the name. The # is 503-852-3170.) at 1200 but I got what seems to be a lot of random characters and it stops at the opening screen when your asked to choose which type board you want, numbered 1,2 and 3. Not matter which number I choose it stops there. I posted a picture for reference. At least I now know that the modem works and I was able to connect to something. Babysteps! The number I listed above 503-852-3170 is the the BBS called "The Keep" Quote Link to comment Share on other sites More sharing options...
moonlight_mile Posted October 22, 2022 Share Posted October 22, 2022 Not to toot our own horn, but the support on the bbs’s is even better. 😂😂 1 Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted October 22, 2022 Share Posted October 22, 2022 3 hours ago, moonlight_mile said: Not to toot our own horn, but the support on the bbs’s is even better. 😂😂 You got that right!!! 1 Quote Link to comment Share on other sites More sharing options...
stushug Posted October 22, 2022 Author Share Posted October 22, 2022 I was able to log into Alcatraz and wander around a bit. Pretty cool. I also got into The Keep, but the problem I had there was each screen was very verbose, and text would scroll by and the screen would roll up before I could read most of it. Is there a way to get those screens to pause before they roll up? 1 Quote Link to comment Share on other sites More sharing options...
Tillek Posted October 22, 2022 Share Posted October 22, 2022 5 minutes ago, stushug said: I was able to log into Alcatraz and wander around a bit. Pretty cool. I also got into The Keep, but the problem I had there was each screen was very verbose, and text would scroll by and the screen would roll up before I could read most of it. Is there a way to get those screens to pause before they roll up? You can try a control - s.... But you probably won't find that problem if you stick to Atari BBS's. Quote Link to comment Share on other sites More sharing options...
stushug Posted October 22, 2022 Author Share Posted October 22, 2022 4 minutes ago, Tillek said: You can try a control - s.... But you probably won't find that problem if you stick to Atari BBS's. You're right, The Keep isn't an Atari BBS. I just realized that, and I now remember the site asking about different systems and it never mentioned Atari. Sometimes I'm a bit slow! Quote Link to comment Share on other sites More sharing options...
Tillek Posted October 23, 2022 Share Posted October 23, 2022 1 hour ago, stushug said: You're right, The Keep isn't an Atari BBS. I just realized that, and I now remember the site asking about different systems and it never mentioned Atari. Sometimes I'm a bit slow! It's all good... I mean, you can call the PeeCee BBS's if you want.... if you want to see the epitome of suxx0r! Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted October 23, 2022 Share Posted October 23, 2022 2 hours ago, stushug said: You're right, The Keep isn't an Atari BBS. I just realized that, and I now remember the site asking about different systems and it never mentioned Atari. Sometimes I'm a bit slow! Try this one (below)... Oops... I forgot you're dialing in... never mind. Quote Link to comment Share on other sites More sharing options...
Tillek Posted October 23, 2022 Share Posted October 23, 2022 10 hours ago, bf2k+ said: Try this one (below)... Oops... I forgot you're dialing in... never mind. I got your back bro! I gave him the dial up modem pool information for BF2K! Quote Link to comment Share on other sites More sharing options...
