prowler Posted October 28, 2022 Share Posted October 28, 2022 Hi All, New to this particular forum. Anyway, to the point. I managed to get my hands on a tape drive for my TI. I had no tapes at the time to use with it but I remember doing a small basic programme and saving/loading it as a test. Now I have managed to get a few things on tape for the TI, I went to use the drive BUT as soon as I hit enter after typing in old cs1, I get the following error: Warning: Check program in memory I/O error 50 The posts I have found in regards to this error show it seems to usually affect people after they start loading not as soon as they issue the command. Was hoping someone could throw some ideas of things I can try to deal with this error. I also tried a save and got an error as soon as I hit enter as well. Thanks Quote Link to comment Share on other sites More sharing options...
Nick99 Posted October 28, 2022 Share Posted October 28, 2022 Hi! Type OLD CS1 instead of old cs1, that should do it. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted October 28, 2022 Share Posted October 28, 2022 All devices are in CAPS CS1 not cs1 also this is in the FAQ 3 Quote Link to comment Share on other sites More sharing options...
jrhodes Posted October 28, 2022 Share Posted October 28, 2022 You generally want to leave CAPS LOCK engaged (down position), unless you are playing a game that uses joysticks, then disengage it (up position). The TI99 is a old-timer, you got to YELL at it before it will understand you 1 2 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted October 28, 2022 Share Posted October 28, 2022 Checking in. 4 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted October 29, 2022 Share Posted October 29, 2022 and Caps Lock = OFF for joystick use 🙃 3 Quote Link to comment Share on other sites More sharing options...
prowler Posted November 12, 2022 Author Share Posted November 12, 2022 Thanks all. I must have found the details the first time I played with the drive when testing it. This time I just looked at the manual that came with it. While it did have the example in caps, it never mentioned anything about it needing to be in caps so it just looked like they were only trying to make the command stand out. Quote Link to comment Share on other sites More sharing options...
