macsonny Posted November 1, 2022 Share Posted November 1, 2022 Hi All, I'm sure I'm not the only one who gets a bit annoyed at how the drive selector is done not he 1050. I have w4 drives and I'm constantly changing drive IDs which is a real pain. Has anyone come up with an elegant mod to change the ID a little more easily? Thanks Quote Link to comment Share on other sites More sharing options...
+Stephen Posted November 1, 2022 Share Posted November 1, 2022 I always thought a nice rotary encoder would be nice, but I've not modded a drive before. BITD I only ever had one drive. Quote Link to comment Share on other sites More sharing options...
macsonny Posted November 2, 2022 Author Share Posted November 2, 2022 4 hours ago, Stephen said: I always thought a nice rotary encoder would be nice, but I've not modded a drive before. BITD I only ever had one drive. Was thinking the same. Can't be that hard. Anyone know the ID selector logic for the pins? Quote Link to comment Share on other sites More sharing options...
Tillek Posted November 2, 2022 Share Posted November 2, 2022 5 hours ago, macsonny said: Hi All, I'm sure I'm not the only one who gets a bit annoyed at how the drive selector is done not he 1050. I have w4 drives and I'm constantly changing drive IDs which is a real pain. Has anyone come up with an elegant mod to change the ID a little more easily? Thanks w4 drives? Not sure if this might point you in the right direction, but my 1035 drive (1050 modified to have a 3.5" mech) has a rotary switch for D1:-D4: on the front. Got it from The Brewing Academy who designed it in conjunction with DropCheck from Bits of the Past. Works great with the Happy 1050 I have next to it. That one is D1:, and if I need both, I set the 1035 to something else... if I need the 1035 to be D1: I just set it to 1 and turn off the Happy 1050. No issues with that so far. 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted November 2, 2022 Share Posted November 2, 2022 8 hours ago, macsonny said: Was thinking the same. Can't be that hard. Anyone know the ID selector logic for the pins? You could use something like this:- https://www.ebay.co.uk/itm/264922342992 and wire it like this 1 Quote Link to comment Share on other sites More sharing options...
+Larry Posted November 2, 2022 Share Posted November 2, 2022 Here's a zip that might help. I've never hooked up more than a 3-drive select using a single toggle switch -- d1, d2, d4. IIRC, the docs show how to use two switches for all 4 drives, so you'd have to adapt that to a rotary switch if you need all 4. 1050 Mods.zip 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 22, 2022 Share Posted November 22, 2022 (edited) MIO, BlackBOX, and certain DOS like SpartaDOS and SpartaDOS X allow you to reassign the drive id map... changing them on the fly during your current session... I keep a few stacks of drives next to each other with ID's duplicated on some... just flip the power off for one and on for the other and such... some speeder upgrades and updates may allow for semi-persistent ID changes as well Edited November 22, 2022 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
