amarok Posted November 4, 2022 Share Posted November 4, 2022 LinguaXE is my first program which uses FujiNet. Its main purpose is to support Google translate functionality for Atari XL/XE. It is very early work in progress demo which is relatively simple yet. On my TODO list I have some ideas for additional features and improvements. For example there will be possiblity to type of international characters. It will give possiblity to set the source language different than English. Also I need to implement error handing routines in case of lack of FujiNet, Internet, Google translate service, etc. The program is implemented in MadPascal using @bocianu libraries dedicated for FujiNet. Some day I will release the program with its source codes. I will keep you informed about the progress of development in this thread. 26 6 Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted November 4, 2022 Share Posted November 4, 2022 Amazing work and a great example of using the Fujinet. 1 Quote Link to comment Share on other sites More sharing options...
+Philsan Posted November 5, 2022 Share Posted November 5, 2022 Great! I suppose it's not possible to use DeepL instead of Google. 1 Quote Link to comment Share on other sites More sharing options...
invisible kid Posted November 5, 2022 Share Posted November 5, 2022 Awesome font 2 1 Quote Link to comment Share on other sites More sharing options...
amarok Posted November 5, 2022 Author Share Posted November 5, 2022 21 hours ago, Beeblebrox said: Amazing work and a great example of using the Fujinet. I have been tempted for a long time to write something for FujiNet - it is so cool device 5 hours ago, Philsan said: I suppose it's not possible to use DeepL instead of Google. Actually, my first attempt was focused on DeepL. To use their API you need provide an authorization key which can be obtained on their site after registration. But there is a catch, you need to give them your credit card information: Quote We need your credit card information in order to prevent misuse of our free API, in particular to prevent fraudulent multiple registrations. Your credit card won't be charged unless you manually upgrade to DeepL API Pro. I would like rather to avoid it, so I decided to not use DeepL for now. But of course it is still relatively easy to implement. 4 hours ago, invisible kid said: Awesome font I use unifont obtained from the following link: https://unifoundry.com/unifont/ 4 Quote Link to comment Share on other sites More sharing options...
amarok Posted December 28, 2022 Author Share Posted December 28, 2022 It's been a while since the last news about LinguaXE. In the meantime, I managed to introduce support for typing international characters from the Atari keyboard. I have prepared 3 keyboards that can be switched with the Option key - Latin, Phonetic Cyrillic and Phonetic Greek. Special characters are entered by Control + the key with the appropriate letter. For example: for the Latin keyboard Ctrl+A gives access to the characters à á â ã ä å æ ā ă ą, for the Cyrillic keyboard, Ctrl+G allows you to choose between ѓ ґ ғ, for Greek keyboard Ctrl+I gives ί ΐ ϊ characters. So far I haven't been able to solve the problem with limiting the length of the request to 256 characters. Therefore, the screen shows a counter of available bytes for entering text. The program makes sure that the allowed length of the text is not exceeded. Theoretically, I could solve the problem of query length limitation by using the HTTP POST method instead of GET. Unfortunately, the Google translation server does not accept this form of communication. One solution is to find another translation engine that uses the POST method. On the other hand, maybe in the future FujiNet's GET method won't have a limit of 256 bytes for URL. 12 Quote Link to comment Share on other sites More sharing options...
amarok Posted January 12, 2023 Author Share Posted January 12, 2023 I prepared a newer version of LinguaXE containing some improvements and error handling. In this version you can find fine-tuned GUI including tips for keyboard operations. I also added a splash screen containing "Atari" words formed in various writing systems. This is also the first public version which you can download and test on your own, if you wish. However, I would like to note that the program has never been tested on the real FujiNet. I expect there might be some issues that I was not able to catch under Altirra emulator. Below you can find some information about program usage. The text to be translated can be typed using one of the three built-in keyboards. The keyboard can be changed between Latin, Phonetic Cyrillic, and Phonetic Greek by pressing the Option key. I attached a pdf file containing a simple instruction about mapping of keys to international characters. By pressing the Return key you can send a translation request and get back the result from Google server. If the request is handled correctly, the translated text will appear at the bottom half of the screen. Otherwise, an error message with the number appears. By pressing Select key you can open a window for selecting languages for translation. The source language is selected on the first screen and the target language on the second one. By pressing a key with a letter from A to Z, you can select the language which name begins with that letter. The Return key confirms your selection. After the translation result is displayed, you can edit the text again just by typing the text. You can also clear the editor by pressing the Clr key. To exit the program you can press the Esc key. Have fun with translation! linguaXE_v0.3.atr LinguaXE keybord layout.pdf 12 Quote Link to comment Share on other sites More sharing options...
invisible kid Posted January 12, 2023 Share Posted January 12, 2023 That just looks really great! The characters reminded me of Antic Mode 3, but I suppose that wouldn't provide the number of characters you would need. 1 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted January 12, 2023 Share Posted January 12, 2023 This is amazing work all around! What a fantastic use of the Fujinet. I will test this on real hardware for you as soon as I can (this weekend). 1 Quote Link to comment Share on other sites More sharing options...
+JAC! Posted January 13, 2023 Share Posted January 13, 2023 Unicode for the win, great idea. And really nice visuals! 1 Quote Link to comment Share on other sites More sharing options...
ndary Posted January 13, 2023 Share Posted January 13, 2023 Hebrew is Missing Quote Link to comment Share on other sites More sharing options...
Dinadan67 Posted January 13, 2023 Share Posted January 13, 2023 I suppose hebrew and arabic will need a special implementation because these languages are written from right to left. Can all nebrew letters be displayed with a 8 pixel wide font? Quote Link to comment Share on other sites More sharing options...
amarok Posted January 13, 2023 Author Share Posted January 13, 2023 (edited) 1 hour ago, Dinadan67 said: Can all nebrew letters be displayed with a 8 pixel wide font? Yes, all characters in Hebrew have 8 pixel width in this font. 1 hour ago, Dinadan67 said: I suppose hebrew and arabic will need a special implementation because these languages are written from right to left. Indeed, there is a problem with direction of printing and writing of text. Especially it would be challenging to print and write text with mixed systems like Hebrew and English. In such a case the direction would change between right->left and left->right. Please take a look for the following article about bidirectional texts:https://medium.com/@rowan/bidirectional-text-for-beginners-f0c5bc1cd97a But it is not the only problem. In Hebrew there are diacritics which are coded as a separate characters. Diacritics should be printed at the same position where the corresponding character is located. In such a case the cursor position is not changed when the diacritic character is printed. Please consider word "עִבְרִית" which means Hebrew. In utf-16 it is coded as U+05e2 U+05b4 U+05d1 U+05b0 U+05e8 U+05b4 U+05d9 U+05ea. The interpretation of particalar characters is as follows: U+05e2 ע U+05b4 ִ U+05d1 ב U+05b0 ְ U+05e8 ר U+05b4 ִ U+05d9 י U+05ea ת 2 hours ago, ndary said: Hebrew is Missing Therefore for now I don't plan to implement support for bidirectional texts. It would quite challenging to introduce such functionality to LinguaXE. Edited January 13, 2023 by amarok 1 Quote Link to comment Share on other sites More sharing options...
ndary Posted January 13, 2023 Share Posted January 13, 2023 Hi Amarok, and if you disregard the diacritic characters, will it make the task easier? most of the diacritic characters are only used for correct pronouncing of the word, not for understanding the translation. Nir 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted January 13, 2023 Share Posted January 13, 2023 (edited) hmmm, I thought pronunciation changed the meaning or context of some words in Hebrew. Having the 8 bit translate Hebrew would still be awesome though, being able to study historical texts on the 8 bit would be pretty nifty. It didn't occur to me modern Hebrew was a thing. Like all things, people change with time, and in the USA mostly no one really speaks or writes Hebrew outside of ceremony or ritual. Though some areas do exist where it's way more prominent. Very interesting and might I add cool idea. Hoping for the best. Edited January 13, 2023 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
amarok Posted January 13, 2023 Author Share Posted January 13, 2023 3 hours ago, ndary said: Hi Amarok, and if you disregard the diacritic characters, will it make the task easier? It would a bit easier to abandon diacritics. But still the most challenging part is to properly render text and move cursor in editor in case of bidirectional contents. Of course I don't give up, but for now I do not have enough time to investigage and implement the algorith from the link I put before. Anyway, I agree that it would be great to do it for 8-bit Atari 1 Quote Link to comment Share on other sites More sharing options...
+Philsan Posted January 15, 2023 Share Posted January 15, 2023 It works! 4 Quote Link to comment Share on other sites More sharing options...
