rietveld Posted November 5, 2022 Share Posted November 5, 2022 I formatted and partioned a disk in my SyQuest drive with 10 EOS partitions How do I add files to these partitions? Quote Link to comment Share on other sites More sharing options...
NIAD Posted November 5, 2022 Share Posted November 5, 2022 The same way that you copy files between disks or data packs. Since you have the system all installed on the SyQuest drive, that means the Hard Drive enhanced version of File Manager is installed, so use III - Boot from Hard Disk and load File Manager. From there it's best to use File Copy functions and then just set you source and destination. In the other thread that you started, there is no way to transfer software from the IDE Zip Drive's zip disk to the SyQuest. I have the IDE Compact Flash Adapter and use ADAMem v1.81 DOS or SDL to add software to a hard disk image file and when ready, use HDDRawCopy to copy the image file back to a CF Card. Quote Link to comment Share on other sites More sharing options...
NIAD Posted November 5, 2022 Share Posted November 5, 2022 P.S. you could use ADAMem as I mentioned to get all your software setup on a hard disk disk image file and then write that to the SyQuest drive however you just setup the SyQuest drive... I assume HDDRawCopy. Quote Link to comment Share on other sites More sharing options...
NIAD Posted November 5, 2022 Share Posted November 5, 2022 this might help 100Mb Dual CF Card ReadMeDOC by N.I.A.D.rtf Quote Link to comment Share on other sites More sharing options...
