tschak909 Posted November 6, 2022 Share Posted November 6, 2022 An upcoming release of @dmsc's FastBASIC for #Atari8bit will include commands for #Fujinet! One of the example programs is a simple @Mastodon client! Source code here: https://github.com/FujiNetWIFI/fastbasic/blob/master/samples/int/mastodon.bas 1 2 Quote Link to comment Share on other sites More sharing options...
janzh Posted November 19, 2022 Share Posted November 19, 2022 On 11/6/2022 at 10:16 PM, tschak909 said: An upcoming release of @dmsc's FastBASIC for #Atari8bit will include commands for #Fujinet! One of the example programs is a simple @Mastodon client! Source code here: https://github.com/FujiNetWIFI/fastbasic/blob/master/samples/int/mastodon.bas GitHub Link = 404 Is it not public? Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted November 19, 2022 Share Posted November 19, 2022 (edited) 9 minutes ago, janzh said: GitHub Link = 404 Is it not public? @tschak909 posted the wrong URL. Try https://github.com/FujiNetWIFI/fastbasic/blob/master/samples/fp/mastodon.bas instead. AFAIK the Fujinet commands are only added to the floating-point version of FastBasic because adding them to the integer version would make the IDE bigger than 8kB which is a self-imposed limit by dmsc. Edited November 19, 2022 by DjayBee 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted November 19, 2022 Author Share Posted November 19, 2022 Yup, dmsc moved it after the pull request. -Thom Quote Link to comment Share on other sites More sharing options...
AngryDill Posted November 28, 2022 Share Posted November 28, 2022 On 11/6/2022 at 3:16 PM, tschak909 said: An upcoming release of @dmsc's FastBASIC for #Atari8bit will include commands for #Fujinet! One of the example programs is a simple @Mastodon client! Source code here: https://github.com/FujiNetWIFI/fastbasic/blob/master/samples/int/mastodon.bas I got a 404 response with the above link. I did find the Mastodon client code there at a slightly different path: https://github.com/FujiNetWIFI/fastbasic/blob/master/samples/fp/mastodon.bas 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted November 29, 2022 Author Share Posted November 29, 2022 yup @dmsc moved it in his upstream, and I pulled to re-sync. -Thom Quote Link to comment Share on other sites More sharing options...
