JohnPCAE Posted November 9, 2022 Share Posted November 9, 2022 (edited) This project is only in its infancy, but it's happening. What you see here is an experimental board that's talking to the Inty about connected USB devices. So far I only have it telling the Intellivision how many devices are connected, but it's only been 24 hours of work. This is nowhere near the final version of the board's layout, but as you can see it's going to be very simple: only three level-shifter ICs, a power MOSFET, and a Pi Pico (and a few passives for a nice clean power rail). The plan is to support (at the very least) keyboards, mice, and gamepads, and if I'm very lucky, mass-storage devices. It's theoretically possible to also add Wifi with a Pi Pico W, and a real-time clock using spare I2C pins. In this picture, it's not my Logitech mouse that's plugged in, but a 4-port USB hub (yes, you can use a hub). And I was testing with a USB gamepad. I've already tested the software with an earlier standalone unit so I already know it can handle a mouse and keyboard plugged in at the same time. In terms of the Inty's memory map, it takes over addresses $007C and $007D, and like the ACC uses a register array. $007C is where you set the register index and $007D is where you read or write the register value. Also like the ACC, one of the registers is a read-only signature register where a magic value tells you if the unit is plugged in. Edited November 9, 2022 by JohnPCAE 12 Quote Link to comment Share on other sites More sharing options...
JohnPCAE Posted November 9, 2022 Author Share Posted November 9, 2022 Correction, I was testing with a USB keypad, not a gamepad. But I do have USB controllers that I plan to eventually test. First I'll work on mouse support, though, as that's easiest. Quote Link to comment Share on other sites More sharing options...
4ever2600 Posted November 9, 2022 Share Posted November 9, 2022 That will be awesome! Quote Link to comment Share on other sites More sharing options...
Rickster8 Posted November 9, 2022 Share Posted November 9, 2022 Awesome Sauce... 1 Quote Link to comment Share on other sites More sharing options...
JohnPCAE Posted November 9, 2022 Author Share Posted November 9, 2022 (edited) Making progress. I have mouse and keyboard events making it to the Inty. There's also a keyboard event buffer that is set to 16 events for now. You can connect multiple keyboards and mice if you really want (I allow a maximum of 16 devices). Next I'll look into gamepads. Edited November 9, 2022 by JohnPCAE Quote Link to comment Share on other sites More sharing options...
JohnPCAE Posted November 10, 2022 Author Share Posted November 10, 2022 (edited) A little more progress. I have data from a Microsoft Sidewinder and an N64 controller (using USB adapters) getting to the Inty. Both are classified as USB HID Joysticks (as opposed to HID gamepads which sends different data). So theoretically, anything classified as a HID joystick should work. I have a couple of other controllers I can test tomorrow, one of which is an MS flight stick. I put in code to process data from HID gamepads as well, but I might not have anything to test it. Edited November 10, 2022 by JohnPCAE Quote Link to comment Share on other sites More sharing options...
8bitwidgets.com Posted November 10, 2022 Share Posted November 10, 2022 Wow that's really slick! So this could be a kind of Fujinet for the Intellvision? I have to put a request in for thinking about MIDI support! Plenty of no frill MIDI USB devices available to provide the IN/OUT ports. Quote Link to comment Share on other sites More sharing options...
JohnPCAE Posted November 10, 2022 Author Share Posted November 10, 2022 (edited) My Logitech Wingman and Microsoft flightstick work (both are also classified as HID joysticks). That only leaves a custom arcade stick I bought a long time ago that's based on an old XBox 360 controller. That doesn't show up at all, so I'll investigate it. It would be cool if it supported original XBox 360 controllers. It's worth pointing out that all USB joysticks require calibration, so any Inty games that support them will have to provide people with a calibration screen. It would be cool if they also saved calibration info to cart storage. One thing I'll look into is supplying the Inty with the USB VID (vendor ID) and PID (product ID) for any controllers to make looking up precalibrated data possible. Edited November 10, 2022 by JohnPCAE Quote Link to comment Share on other sites More sharing options...
+Lathe26 Posted November 10, 2022 Share Posted November 10, 2022 I don't know what protocol XBox 360 controllers use, but the original XBox controllers used a proprietary Microsoft protocol called XID. However, it is easy to create a driver for it since XID uses fixed-format packets that are HID-like. To support them, either 1) parse the raw packets yourself or 2) create a fake HID descriptor that describes the fixed-format packet and feed it into the existing HID joystick driver. I recommend adding support for the original XBox controller only if it is easy for you to implement. https://xboxdevwiki.net/Xbox_Input_Devices Quote Link to comment Share on other sites More sharing options...
JohnPCAE Posted November 10, 2022 Author Share Posted November 10, 2022 (edited) That explains why TinyUSB isn't even seeing it mounted. It's not even calling the HID mount callback routine. I think I'll just skip that controller then and move on to diagnosing detecting devices that are already plugged in. It detects a device if you plug it in after the Inty is powered up, but it's not seeing devices that were already plugged in. I could have sworn that was working earlier. I'm also wondering if I can store calibration data in the Pi Pico's flash memory. I don't know if it's feasible but that would mean that calibration could be persistent across game sessions and even from one game to another. Edit...Aha. It's the hub. If it's already plugged into the hub then the software in the Pico gets confused. But if it's already plugged in directly without a hub it works fine. So that's something else to investigate. That might be a TinyUSB issue. Edited November 10, 2022 by JohnPCAE Quote Link to comment Share on other sites More sharing options...
JohnPCAE Posted November 11, 2022 Author Share Posted November 11, 2022 (edited) This is untested, but I've added code to load/save 4k (2k words) of calibration data to the Pi Pico's flash memory. So theoretically a game could read the VID and PID of a controller, load the calibration data, and if there isn't a block for that controller somewhere in the data, let players calibrate their controller and save it to flash (or let them recalibrate whenever they want). The nice thing is that the calibration data would be persistent across sessions and even games. We would all have to agree on a memory layout standard for calibration data though. The memory area is large enough that it could store calibration data for many controllers at once. It's probably enough to store data for as many controllers as any of us could ever own. Edited November 11, 2022 by JohnPCAE Quote Link to comment Share on other sites More sharing options...
JohnPCAE Posted November 12, 2022 Author Share Posted November 12, 2022 (edited) I've figured out how to set the LED's on a keyboard and I've added some initial code for mass-storage devices (you can get some basic info like block size and number of blocks). I've also started looking at MIDI device support, but this might be difficult since I don't have any. As for mass-storage devices, dealing with device format (FAT16, FAT32, NTFS, etc.) will be outside the scope of this project. I plan to let the Inty read or write raw data but interpreting the format will be up to Inty software. I'm providing an 8k shared memory area that can be used for anything requiring a buffer (controller calibration, mass storage data, etc.). You access it via a couple of registers: data pointer and data value. Reading or writing to the data value register auto-increments the data pointer. Edited November 12, 2022 by JohnPCAE Quote Link to comment Share on other sites More sharing options...
JohnPCAE Posted November 12, 2022 Author Share Posted November 12, 2022 Hmm. TinyUSB doesn't yet have a host-mode driver for USB audio devices, so MIDI won't be happening for now. But at least HID devices are working and I've completed putting in code for mass-storage devices, though that's still untested. Quote Link to comment Share on other sites More sharing options...
+Lathe26 Posted November 12, 2022 Share Posted November 12, 2022 On 11/11/2022 at 3:03 AM, JohnPCAE said: This is untested, but I've added code to load/save 4k (2k words) of calibration data to the Pi Pico's flash memory. So theoretically a game could read the VID and PID of a controller, load the calibration data, and if there isn't a block for that controller somewhere in the data, let players calibrate their controller and save it to flash (or let them recalibrate whenever they want). The nice thing is that the calibration data would be persistent across sessions and even games. We would all have to agree on a memory layout standard for calibration data though. The memory area is large enough that it could store calibration data for many controllers at once. It's probably enough to store data for as many controllers as any of us could ever own. If you have access to the device's serial number (not all USB devices include this), that would be the best way to know what calibration data goes with which device. Falling back to using VID/PID is so-so since it is likely the user only owns 1 of that particular make/model and a production run of a make/model would likely have similar calibration offsets. Quote Link to comment Share on other sites More sharing options...
+Lathe26 Posted November 12, 2022 Share Posted November 12, 2022 13 minutes ago, JohnPCAE said: Hmm. TinyUSB doesn't yet have a host-mode driver for USB audio devices, so MIDI won't be happening for now. But at least HID devices are working and I've completed putting in code for mass-storage devices, though that's still untested. Check for a MIDI-specific driver since that protocol is audio-related but not audio itself. By itself, MIDI just transmits sheet music (i.e. what notes to play when on which instrument) but not the audio itself. This is why the pre-USB MIDI cable just transmits at 31Kbps. The USB version of the MIDI protocol is fairly simple. Quote Link to comment Share on other sites More sharing options...
JohnPCAE Posted November 12, 2022 Author Share Posted November 12, 2022 11 minutes ago, Lathe26 said: If you have access to the device's serial number (not all USB devices include this), that would be the best way to know what calibration data goes with which device. Falling back to using VID/PID is so-so since it is likely the user only owns 1 of that particular make/model and a production run of a make/model would likely have similar calibration offsets. I'm not suggesting that we would supply calibration data but only that when people calibrated their controllers the VID and PID would be stored along with the calibration data in flash. That way it could be retrieved at a later time by either the same or a different game and matched with the controller. The idea is that if a person has multiple USB controllers of different types it could match the correct calibration data with the correct controller. Quote Link to comment Share on other sites More sharing options...
+fdr4prez Posted November 12, 2022 Share Posted November 12, 2022 35 minutes ago, JohnPCAE said: I'm not suggesting that we would supply calibration data but only that when people calibrated their controllers the VID and PID would be stored along with the calibration data in flash. That way it could be retrieved at a later time by either the same or a different game and matched with the controller. The idea is that if a person has multiple USB controllers of different types it could match the correct calibration data with the correct controller. I think @Lathe26 is saying, what if you have two controllers that need different calibrations, but they have the same VID/PID? This is an issue with RetroPi when you want different controller mapping due to the controllers being different but they have the same PID. 1 Quote Link to comment Share on other sites More sharing options...
+Lathe26 Posted November 12, 2022 Share Posted November 12, 2022 3 hours ago, JohnPCAE said: I'm not suggesting that we would supply calibration data but only that when people calibrated their controllers the VID and PID would be stored along with the calibration data in flash. That way it could be retrieved at a later time by either the same or a different game and matched with the controller. The idea is that if a person has multiple USB controllers of different types it could match the correct calibration data with the correct controller. I wasn't suggesting supplying the calibration data either. The idea is when people calibrate their controllers the VID and PID USB serial number would be stored along with the calibration data in flash. Only use the VID/PID as a backup alternative if the USB serial number isn't available for that particular device. 1 Quote Link to comment Share on other sites More sharing options...
JohnPCAE Posted November 12, 2022 Author Share Posted November 12, 2022 I see. It looks like the serial number is a single byte. I can add a routine to TinyUSB to retrieve it and store that as well as the VID and PID. 1 Quote Link to comment Share on other sites More sharing options...
+Lathe26 Posted November 13, 2022 Share Posted November 13, 2022 19 hours ago, JohnPCAE said: I see. It looks like the serial number is a single byte. I can add a routine to TinyUSB to retrieve it and store that as well as the VID and PID. It is a variable length string that can be a max of 253 bytes long (limit set by USB descriptor length max). It should be UTF-16-LE string encoded (i.e. each character is 16-bits wide, little-endian). You can either store it as string or as a byte array, whichever is easier. Quote Link to comment Share on other sites More sharing options...
JohnPCAE Posted November 13, 2022 Author Share Posted November 13, 2022 I see. Okay I've set it up so that the Inty can command it to retrieve a gamepad's USB serial number and dump it into the shared memory buffer. Quote Link to comment Share on other sites More sharing options...
JohnPCAE Posted November 14, 2022 Author Share Posted November 14, 2022 (edited) I had to add some code to TinyUSB but I have it properly mounting my 4GB USB stick now. It doesn't like my 8GB stick, though. I'm not sure why. I'm getting DEVICE_ATTACH and DEVICE_REMOVE events but no other events from it. I'm specifically looking for a XFER_COMPLETE event but not getting any. Edited November 14, 2022 by JohnPCAE Quote Link to comment Share on other sites More sharing options...
JohnPCAE Posted November 15, 2022 Author Share Posted November 15, 2022 Got all my USB sticks mounting (I tested 5 of them). I haven't tried reading anything from them, but they're mounting and unmounting with no problems. Quote Link to comment Share on other sites More sharing options...
JohnPCAE Posted November 15, 2022 Author Share Posted November 15, 2022 Well, well. Someone has added a MIDI host driver to a fork of TinyUSB: https://github.com/rppicomidi/tinyusb/tree/pio-midihost I've integrated it into my TinyUSB library, which means I could conceivably support plugging in a single MIDI device (a single MIDI device is all his driver supports). I'll start looking into adding support tomorrow, but I don't have any MIDI devices to test (a musician I am not). Short of someone with a MIDI device building one of my USB boards and having me send them the microcontroller software (and then they'd have to write something for the Inty to actually use it) I'm not sure how to test it. Quote Link to comment Share on other sites More sharing options...
JohnPCAE Posted November 15, 2022 Author Share Posted November 15, 2022 I've put in some tentative support for sending packets over USB to a MIDI device, but I have no way to test it... Quote Link to comment Share on other sites More sharing options...
