+slx Posted November 15, 2022 Share Posted November 15, 2022 I built an SDrive Max some time ago and used it infrequently. It was working with firmware 1.0 which I upgraded to the latest beta of 1.3 available on GitHub today. After re-flashing it it still works when connected to the Atari but I don't get any response from the touchscreen. The screen driver seems to be the right version (using another screen driver with a different but legible color scheme does not help either and I am pretty sure I have a 9341 screen anyway - at least that what it displays at startup). Could it be that the screen needs re-calibration? While the documentation says that touching the screen during startup will force calibration mode, this does not happen. Any tricks/hints/suggestions welcome! Thanks! Quote Link to comment Share on other sites More sharing options...
Mrshoujo Posted November 15, 2022 Share Posted November 15, 2022 36 minutes ago, slx said: Could it be that the screen needs re-calibration? While the documentation says that touching the screen during startup will force calibration mode, this does not happen. Are you holding down your touch long enough? Think Long Tap using Chrome on Android to save an image. Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted November 16, 2022 Share Posted November 16, 2022 Pressing on the touchscreen when powering up SDrive max should bring up the calibration screen, assuming the correct screen driver is installed -SteveS Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted November 16, 2022 Share Posted November 16, 2022 From De Re Sdrivemax website:https://atari8bit.net/tutorials/de-re-sdrive-max/ Once you have built your SDrive-MAX, it will need to have the SDrive-MAX software on it for it to work. You can get the latest release of the software from the GitHub page of the developers. The latest release is always at the top, you want the zip file from the assets section. Download it and unzip it; you will find some documents and five folders named “atmega328-<screen-driver>“. Pick the folder with the right driver for your screen. If you don’t know which driver your screen uses, it doesn’t matter, you can just do this for each folder in turn until you get the right one, you cannot brick your SDrive-MAX by doing this. Quote Link to comment Share on other sites More sharing options...
+slx Posted November 19, 2022 Author Share Posted November 19, 2022 I tried all of them and the 9341 worked. I got a slightly different screen with strang colors using another but no touch with either. Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted November 19, 2022 Share Posted November 19, 2022 perhaps the screen itself is faulty? Quote Link to comment Share on other sites More sharing options...
+slx Posted November 20, 2022 Author Share Posted November 20, 2022 On 11/19/2022 at 10:37 AM, Beeblebrox said: perhaps the screen itself is faulty? It worked before I upgraded the firmware, so I doubt that a bit. But I should have another screen somewhere to test. Thanks for the hint. Quote Link to comment Share on other sites More sharing options...
xrbrevin Posted November 21, 2022 Share Posted November 21, 2022 On 11/19/2022 at 9:37 AM, Beeblebrox said: perhaps the screen itself is faulty? maybe a clone, there are many about Quote Link to comment Share on other sites More sharing options...
kbr Posted December 4, 2022 Share Posted December 4, 2022 Sounds like you haven't flashed the eeprom_writer.hex before. 1 Quote Link to comment Share on other sites More sharing options...
