ldelsarte Posted November 19, 2022 Share Posted November 19, 2022 Dear Atari fans, Yes, ATARI Basic has weaknesses and we all know them. I wanted to demonstrate that one of its strengths is that a program can be self-modifying. I wrote the following two programs: PART1.BAS 10 OPEN #1,8,0,"D:ADDLINES.TXT" 20 PRINT #1;"1000 A=990:B=980" 30 CLOSE #1 40 RUN "D:PART2.BAS" PART2.BAS 10 A=10:B=20 20 ?A,B 40 ENTER "D:ADDLINES.TXT" 50 GOSUB 1000 60 ?A,B 70 END 1000 REM PLACE HOLDER 1999 RETURN Well, it doesn't work as expected at all. In PART2.BAS, line 40 ENTER "D:ADDLINES.TXT" is executed, which updates line 1000 A=990:B=980 However, the program stops immediately at line 40, and does not execute the rest. ENTER behaves as if it had been executed in direct mode, and not in a program. So it returns control to the Atari BASIC editor, instead of continuing at line 50. I have several questions: [1] Does anyone have an explanation? [2] Does anyone know of a similar - but working - way to get a program to modify itself by loading bits of code from diskette? [3] I remember programs that would auto-modify by opening E: or S: in mode 13 (OPEN #1,13,0, "E:" or "S:"), then displaying new lines on the screen, and by positioning the cursor, the editor would simulate a "RETURN", so that the lines were actually added to the program, without the user pressing any keys. Does anyone remember this? And more importantly, does anyone remember how to do this exactly? Thank you very much in advance, Laurent part1.bas part2.bas Quote Link to comment Share on other sites More sharing options...
vitoco Posted November 19, 2022 Share Posted November 19, 2022 What if you add a RUN or GOTO 50 line at the end of the txt file? 1 Quote Link to comment Share on other sites More sharing options...
ldelsarte Posted November 19, 2022 Author Share Posted November 19, 2022 (edited) 12 minutes ago, vitoco said: What if you add a RUN or GOTO 50 line at the end of the txt file? Ta-da! Great suggestion @vitoco, it was exactly what was missing! Thank you for much for this pertinent suggestion. With PART1.BAS now reading 10 OPEN #1,8,0,"D:ADDLINES.TXT" 20 PRINT #1;"1000 A=990:B=980" 25 PRINT #1;"GOTO 50" 30 CLOSE #1 40 RUN "D:PART2.BAS" It "resumes" PART2.BAS at line 50, as I wished. (enclosed updated PART1.BAS) part1.bas part2.bas Edited November 19, 2022 by ldelsarte Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted November 19, 2022 Share Posted November 19, 2022 Just for fun, another way to load your file, although a bit long winded compared to @vitoco 's solution. 10 ? Chr$(125) 20 A=10:B=20 30 Position 2,10:? A,B 35 REM POSITON EVERTHING ON SCREEN 40 Position 2,2:? "ENTER ";Chr$(34);"D:ADDLINES.TXT";Chr$(34) 45 Position 2,5:? "CONT" 46 Position 2,0 50 Poke 842,13:REM TURN ON AUTO RETURN 60 Stop:REM STOP THE PROGRAM , WILL NOW ENTER FILE 70 Poke 842,12: REM TURN OFF AUTO RETURN 75 REM PROGRAM RESUMES 80 Gosub 1000 90 Position 2,12:? A,B 100 End 1000 Rem DUMMY LINE 1010 Return 1 Quote Link to comment Share on other sites More sharing options...
ldelsarte Posted November 19, 2022 Author Share Posted November 19, 2022 10 minutes ago, TGB1718 said: Just for fun, another way to load your file Thanks very much, @TGB1718 My memory was flawed. In my memory, to do exactly what you are doing (which works perfectly), you had to open a channel with S: or E: in mode 13. Your program shows that this is unnecessary. Thanks for the tip! Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 19, 2022 Share Posted November 19, 2022 Yep, alternate method is putting stuff onscreen then using forced input mode. Once debugged you can turn screen off or set foreground to same as background colour to hide what's happening. I used this a fair bit in the day, largely for generating Data statements of short asm routines. And yep, other computers tend to not be able to do it, or at least not easily. C64 you can sort of do it. But entering a new line clears all variables so you need to Poke variables you want to keep then restore them later. It has the keyboard buffer so you can just store a bunch of Returns in there. 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted November 19, 2022 Share Posted November 19, 2022 50 minutes ago, Rybags said: I used this a fair bit in the day, largely for generating Data statements of short asm routines. Something like this, not sure if it's the final version, but I think I got £25 for an inclusion in a magazine bitd AUTODA.BAS 1 Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted November 19, 2022 Share Posted November 19, 2022 At least one of the BBS programs I ran back in the 80's used this technique to initialize variables and then delete lines of code to free up memory for the bbs to run in. Particularly needed when I ran on a stock 800. 2 Quote Link to comment Share on other sites More sharing options...
NorbertP Posted November 19, 2022 Share Posted November 19, 2022 I wrote a program to plot graphs of algebraic functions, and used the self modifying code to compensate for the lack of an EVAL() statement - it was a little clunky, but a heck of a lot easier than writing some sort of parser! 2 Quote Link to comment Share on other sites More sharing options...
thorfdbg Posted November 19, 2022 Share Posted November 19, 2022 6 hours ago, ldelsarte said: [1] Does anyone have an explanation? [2] Does anyone know of a similar - but working - way to get a program to modify itself by loading bits of code from diskette? [3] I remember programs that would auto-modify by opening E: or S: in mode 13 (OPEN #1,13,0, "E:" or "S:"), then displaying new lines on the screen, and by positioning the cursor, the editor would simulate a "RETURN", so that the lines were actually added to the program, without the user pressing any keys. Does anyone remember this? And more importantly, does anyone remember how to do this exactly? The explanation is that ENTER does enter the direct mode. The way how "enter" works is that it opens the file, then sets the "stdin" of the basic editor to that file, and then enters the direct mode. Thus, the lines the user would otherwise type in through E: now come through the opened file as the direct mode of Basic would continue to read from its stdin, now the file just opened. On an EOF, the Basic interpreter closes the file, and restores its "stdin" to channel #0, which is connected to E:. Thus, what you see is an artefact due to how "Enter" works. It is actually a quite simple command that performs just rediction. [2] was already answered, you need to get code executed by the direct mode that puts basic back into the run mode. [3] works by placing the E: handler into the "auto-enter" mode. That is, the E: handler then no longer waits for return to be pressed, but continues to read data from the screen. If I recall correctly, this was a "POKE 842,13" or so, which is the open-mode of channel #0, connected to E: That is actually not a feature of the basic, but a feature of the operating system. 1 1 Quote Link to comment Share on other sites More sharing options...
atarixle Posted November 19, 2022 Share Posted November 19, 2022 2 hours ago, NorbertP said: I wrote a program to plot graphs of algebraic functions, and used the self modifying code to compensate for the lack of an EVAL() statement - it was a little clunky, but a heck of a lot easier than writing some sort of parser! I guess I remember that program. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted November 19, 2022 Share Posted November 19, 2022 2 hours ago, thorfdbg said: If I recall correctly, this was a "POKE 842,13" see my post #4 in this thread Quote Link to comment Share on other sites More sharing options...
