TGB1718 Posted November 27, 2022 Share Posted November 27, 2022 I have a couple of USB to Serial adaptors that I've tried many times to use with my 8 Bits (800,800XL,130XE) and the result is the same, intermittent/poor communications making it unreliable, I have 2 different USB devices and they both act the same way. My SIO2PC is an original I built back in the 90's using Nick Kennedy's original documentation, I know the SIO2PC works fine as I have a couple of old PC's that work well with it. So I bought one of these and put it in my PC:- https://www.ebay.co.uk/itm/303920047558 £8.99 including post and packing (bargain), it installs itself as Multifunction Adaptors (one for each port) and then 2 new COM ports appear under Ports (COM & LPT) where you can configure them if needed. I ran RespeQt using PCL3: on my 130XE, it worked fine, no errors and I was really pleased, so I then configured it to run at divisor zero, it can run all day with this setting, no errors and my cable between 8 bits and PC is over 15 feet long. One happy boy here 3 Quote Link to comment Share on other sites More sharing options...
+Larry Posted November 28, 2022 Share Posted November 28, 2022 Glad it has worked well for you, but I am surprised about your lack of success with the USB setup. My first thought is whether the +15 feet is an issue. Did you have real FTDI chips for the converters? A lot of the knock-offs didn't work well. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted November 29, 2022 Author Share Posted November 29, 2022 On 11/28/2022 at 1:19 AM, Larry said: My first thought is whether the +15 feet is an issue. With SIO2PC I used a genuine MAX232 chip, so for that the length is fine (don't think the Chinese knock of factories had been built then ) On 11/28/2022 at 1:19 AM, Larry said: Did you have real FTDI chips for the converters? A lot of the knock-offs didn't work well. Unknown as the are sealed, you are probably right about the length when using one of these as they probably don't handle noise very well. I do have some USB FDTI convertors but it would be a bit messy connecting one of these without putting a plug/cable on one. 1 Quote Link to comment Share on other sites More sharing options...
MrFSL Posted December 7, 2022 Share Posted December 7, 2022 On 11/27/2022 at 6:47 AM, TGB1718 said: One happy boy here Sounds like you have a solution that makes you happy so that's good. On 11/27/2022 at 6:47 AM, TGB1718 said: I have a couple of USB to Serial adaptors that I've tried many times to use with my 8 Bits (800,800XL,130XE) and the result is the same, intermittent/poor communications making it unreliable, I have 2 different USB devices and they both act the same way. I don't think this is a post asking for any help or advise, more like reporting in on your experience. But for what it might be worth I had similar problems. I purchased these devices: https://www.amazon.com/gp/product/B07D9R5JFK/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 which I were described as known working and yet they worked poorly. I then went through several others. Ultimately I found 2 devices that worked well: https://www.amazon.com/gp/product/B07FVHNF31/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 and https://www.amazon.com/gp/product/B07BBPX8B8/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 so to Larry's point, I wouldn't say your experience is typical and might have something else to do with what you are using. I just think that cable lengths and chips were Larry possibly misreading what you posted; that these cable lengths were in relation to the SIO2PC solution you ended up with, not the USB solutions you were initially having issues with. Quote Link to comment Share on other sites More sharing options...
+Larry Posted December 8, 2022 Share Posted December 8, 2022 I assumed the 15 ft applied to both setups. 15 ft would be quite acceptable to a true RS232. I don't know about a usb converter, hence my thinking it might be a source of the problem. But to reiterate, nearly all problems I have heard of resulted from ftdi clones. One even bit me. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted December 8, 2022 Author Share Posted December 8, 2022 10 hours ago, Larry said: I assumed the 15 ft applied to both setups. 15 ft would be quite acceptable to a true RS232. I can remember back in the 80's setting up a remote terminal (VT100) in another room at work with a direct connection to the computer via RS232, we had to use a 120 foot long cable and it worked fine, I suppose that's what you get when the logic levels are +/- 12VDC Quote Link to comment Share on other sites More sharing options...
