naujoks Posted November 28, 2022 Share Posted November 28, 2022 I just installed an Ultimate 1MB in my 800XL. I wanted to use it with my Fujinet, but it's not working. It's trying to boot sometimes but then halts, sometimes it boots successfully but then freezes during operation. I tried what's been suggested elswhere, booting into SpartaDOS, then resetting Fujinet and typing COLD /N, but that doesn't work either. I connected the Fujinet to USB power, that seemed to make things a bit more stable than without, but not much. Anything else I could try? Is Fujinet and U1MB not the best combination? What's better? Quote Link to comment Share on other sites More sharing options...
+Stephen Posted November 28, 2022 Share Posted November 28, 2022 1 hour ago, naujoks said: I just installed an Ultimate 1MB in my 800XL. I wanted to use it with my Fujinet, but it's not working. It's trying to boot sometimes but then halts, sometimes it boots successfully but then freezes during operation. I tried what's been suggested elswhere, booting into SpartaDOS, then resetting Fujinet and typing COLD /N, but that doesn't work either. I connected the Fujinet to USB power, that seemed to make things a bit more stable than without, but not much. Anything else I could try? Is Fujinet and U1MB not the best combination? What's better? Sorry I cannot help with the FujiNet issue. Regarding your other question: Depends on what you mean by better. FujiNet is a serial device meaning it can only run disk or cassette images, along with the cool online features it provides. If you want something like a multi-cart, then SIDE2, SIDE3 (or AVG which can emulate SIDE2) really shine with the U1MB as you get a parallel port based hard drive capable of 60 to 90kB/sec loading times depending on DOS used. They can also play cart (ROM) based images as well they offer specialized audio and video playback which is only possible via hard drive. 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 28, 2022 Share Posted November 28, 2022 (edited) @naujoks If your Atari still has the filter caps on it's SIO port, you should remove them. Fujinet sometimes seems to get into a fight over I/O routines and such, please configure any high speed patches etc. so that they are not interfering. Furthermore Make sure you have both the Fujinet and the U1M configured about the same for most things (SDX user area config, startup)... this keeps the experience even, and limits some surprises. make sure the headers and ribbons are mated properly so there is not intermittent or high resistance connection within the header or the socket they plug into. if everything is good but the u1m and fujinet still don't get along, try reflashing them both, and make sure to reprogram the u1m as well. failing that you would then consider a hardware issue with the fuji,atari, or u1m Edited November 28, 2022 by _The Doctor__ 1 Quote Link to comment Share on other sites More sharing options...
naujoks Posted November 28, 2022 Author Share Posted November 28, 2022 I haven't removed any caps. Which ones are the ones to be removed? Quote Link to comment Share on other sites More sharing options...
TZJB Posted January 4 Share Posted January 4 On 11/28/2022 at 7:04 PM, naujoks said: I haven't removed any caps. Which ones are the ones to be removed? Maybe a bit late for this one, C76 and C77 sit across the SIO DATA IN and DATA OUT lines. Quote Link to comment Share on other sites More sharing options...
