eizner23 Posted December 2, 2022 Share Posted December 2, 2022 Maybe you played this as youth in the late 80's after playing Atari. The stuffed potato played a tune after being triggered by a squeeze, you passed it around. When tune randomly stops you pick a card. I want to pass along my hot potato to a nephew but it needs service. The coin battery was corroded. It had no markings on it. I tested it with a LR44 1.5v alkaline, it worked but the output was about 1/3 of what is should be. I tried a new 27mm coin piezo with same results. Hail mary with 3v battery thinking maybe it was a custom battery, but it played really slow. Its fascinating this little epoxy glob can store a melody, a timer of sorts and the means to amplify playback. Did it loose some of its amplification magic over the decades, or battery issue? Its just not loud enough. A disk cap, pressure pad-type switch, and the tiny IC that is it. Quote Link to comment Share on other sites More sharing options...
