Steve Mynott Posted December 26, 2022 Share Posted December 26, 2022 Is there anyway of accessing the host (H:) drive under emulation using MyDOS? Quote Link to comment Share on other sites More sharing options...
+MrFish Posted December 26, 2022 Share Posted December 26, 2022 5 minutes ago, Steve Mynott said: Is there anyway of accessing the host (H:) drive under emulation using MyDOS? Worked right off for me (v4.53). What version of MyDOS are you trying to use?...and what emulator? (I'm using Altirra v4.01) Quote Link to comment Share on other sites More sharing options...
Steve Mynott Posted December 26, 2022 Author Share Posted December 26, 2022 Oh it does work with the A option. I'm too used to using 1-8 and * D'uh. Quote Link to comment Share on other sites More sharing options...
+MrFish Posted December 26, 2022 Share Posted December 26, 2022 4 minutes ago, Steve Mynott said: Oh it does work with the A option. I'm too used to using 1-8 and * D'uh. Yeah, I was thinking the same thing at first too. I went into BASIC and tried running and saving some files too (before I replied), which worked. I figured everything should work, because it's DOS 2.x'ish, and I use that all the time. 1 Quote Link to comment Share on other sites More sharing options...
atarixle Posted December 26, 2022 Share Posted December 26, 2022 (edited) H: is a totally indepentend device and is in no way influenced by MyDOS or any other DOS (exept SpartaDOS which might map H: to D8: internally). So H: should work in any DOS, but might not be supported by menu driven utilities as the output-format of DIR "H1:*.*" might variate from Emulator to Emulator, and differ from DOS. Edited December 26, 2022 by atarixle Quote Link to comment Share on other sites More sharing options...
Steve Mynott Posted December 27, 2022 Author Share Posted December 27, 2022 16 hours ago, atarixle said: H: is a totally indepentend device and is in no way influenced by MyDOS or any other DOS (exept SpartaDOS which might map H: to D8: internally). So H: should work in any DOS, but might not be supported by menu driven utilities as the output-format of DIR "H1:*.*" might variate from Emulator to Emulator, and differ from DOS. SpartaDOS doesn't use H: for the host drive, it uses the PCL: device via PCLINK. Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted December 27, 2022 Share Posted December 27, 2022 2 hours ago, Steve Mynott said: SpartaDOS doesn't use H: for the host drive, it uses the PCL: device via PCLINK. You're talking about SpartaDOS X. Earlier versions of SpartaDOS (3.x) use the H: device. Quote Link to comment Share on other sites More sharing options...
