How should I be using RAND?
Words Fail
DPC+ kernel so I don't need  RAND16.
shootmissilebottom
 rem l=rand
 if rand<=30 then missile1height=14: missile1x=player1x+10: missile1y=player1y-14: k=1
 return thisbank
shootmissiletop
 rem m=rand
 if rand<=30 then missile0height=14: missile0x=player2x+10: missile0y=player2y+14: n=1
 return thisbank
If either top or bottom missile is to fire it goes to one of those. I can see the pattern. I fly up, right, up, left, and the first two bullets usually come out at the exact same spots.. I continue to fly around level and I can usually see the bullets in the some of the same spots.
I don't understand what you are trying to do well enough to know why it isn't working as you expected. It doesn't seem like your missile starting location is at all random, but based on the player's position.
Of course it's based on the player (enemy) position. It's a space ship that fires out of the ship. The randomness is to tell if the ship if it should fire or not.
So, the enemy is moving across the screen, and you are noticing that it seems to "randomly" fire when it is in the same place? I follow now, I think.
To get more of a feeling of randomness, you can read from rand at times based on the player's actions, so it would presumably be different each time. Basically you are using the player. Something simple like "if joy0fire then temp1=rand" will cycle the random number generator at non-predictable times, and usually lead to a more random-seeming result for when you do use the rand value for something like this.
DPC+ uses a better random number generator
shootmissilebottom
 rem l=rand
 return thisbank
shootmissiletop
 rem m=rand
 return thisbank
What happens if you have one that is if rand<31 and the other one that is if rand>224? Does that change the pattern?
If you are trying to get an enemy firing but why less discernible pattern sometimes I may do something like have the code for the firing only activate if the enemy was within a certain range of the player.
so if the enemy is moving vertically I may look to see if the enemy y coordinates are close to the player y. And if then it may fire.
other times I may tie the generation of the random firing to something like a timer or a coordinate of something. I will play around with it and tweak until it just feels right.
I still like to reference R.T.s rand usage charts:
https://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#rand
A pro game maker move is to seed rand when the player first presses the FIRE button.  I do this when they exit the title screen.  Since humans are pretty random you're almost sure to get a unique set of numbers coming out of rand.
title
 counter = counter + 1
 if joy0fire then rand = counter : goto maingame
 goto title
1 hour ago, bogax said:
I don't know what DPC+ does but normally if you use rand in the predicate of an if statement it does'nt call the rand function it just references the rand seed/variable
Ahh; I didn't realize that, but that's good to know. So, in addition to my advice, I'd suggest @Words Fail try setting a temp variable to rand, and then using the temp variable in the code in question.
