krap Posted January 2, 2023 Share Posted January 2, 2023 Hi, I'm trying to reanimate a REV 1.0 PC4, motherboard C103524-001, and I'm getting 4 beeps on the boot up, no video at all. The motherboard is clean, however the case has some acid stains, so I expect there was a battery problem here some time ago. J35 is not connected to anything. I've browsed through the French manual that is available online, but no information on further debugging than the 4 beeps mean real time clock problem. I've tried to connect CR2032 to J35, with no success though. Do you have any more detailed reference on the motherboard and the jumpers/pinout? What kind of battery should be connected and to what pins exactly? Any ideas on how to proceed further? Quote Link to comment Share on other sites More sharing options...
zzip Posted January 3, 2023 Share Posted January 3, 2023 If you know what BIOS it uses (I don't offhand) you could potentially look up the POST beep codes for that BIOS. It's more likely BIOS specific than Atari specific Quote Link to comment Share on other sites More sharing options...
krap Posted January 3, 2023 Author Share Posted January 3, 2023 Yes, I've checked in the manual. It is 'clock error'. But I guess even with the battery it should proceed. Maybe? Quote Link to comment Share on other sites More sharing options...
edintv Posted January 3, 2023 Share Posted January 3, 2023 Have you inspected the Bios chip itself? some old ones they just have the battery soldered to the chip and caused a mess. Quote Link to comment Share on other sites More sharing options...
krap Posted January 10, 2023 Author Share Posted January 10, 2023 Problem solved - it was the oscillator siting under the power supply. The seating was loose and at least one leg was not having contact. After reseating it started ok. Quote Link to comment Share on other sites More sharing options...
