pwwit1 Posted January 4 Share Posted January 4 Hello, I'm trying to setup a lynx toolchain again, and reading the posts here I used Karri's template and cc65 like so: 1. Installed dependencies with: sudo apt-get install git checkinstall mednafen 2. Removed my install of cc65: sudo apt-get remove cc65 3. Installed cc65: git clone https://bitbucket.org/atarilynx/lynx.git cd lynx/tools make -f Makefile.deb Builds and installs ok. 4. Grabbed the template from here: https://forums.atariage.com/topic/287147-is-10-fps-a-too-low-framerate-for-a-lynx-tile-based-game/page/2/ Builds ok and creates a cart/game.lyx But unfortunately it loads up to a blank screen. If i use the precompiled cc65 from the same forum post (cc65_14.09-1_amd64.deb) I can build and run template with no problems! There are no obvious errors when building cc65, so I'm at a loss as to what is going on. Does anyone have any suggestions, or am I trying to use an old toolchain? Thanks for any response Paul Quote Link to comment Share on other sites More sharing options...
+karri Posted January 4 Share Posted January 4 You need to change the cart/directory.s macro. There is 4 word fields now. The block is not a byte anymore. .macro entry old_off, old_len, new_off, new_block, new_len, new_size, new_addr new_off=old_off+old_len new_block=new_off/__BLOCKSIZE__ new_len=new_size .word new_block .word (new_off & (__BLOCKSIZE__ - 1)) .word new_addr .word new_len .endmacro ; Entry 0 - first executable _MAIN_FILENR=0 entry __STARTOFDIRECTORY__+(__DIRECTORY_END__-__DIRECTORY_START__), 0, mainoff, mainblock, mainlen, __STARTUP_SIZE__+__INIT_SIZE__+__CODE_SIZE__+__RODATA_SIZE__+__DATA_SIZE__, __STARTUP_LOAD__ _HM_FILENR=_MAIN_FILENR+1 entry mainoff, mainlen, hmoff, hmblock, hmlen, __HM_CODE_SIZE__+__HM_RODATA_SIZE__+__HM_DATA_SIZE__, __HM_START__ ... The reason for this is that one of my games I am developing exceeds 512k and the new header works for carts up to 2MB. I also hope to make this change to the official cc65. Quote Link to comment Share on other sites More sharing options...
OldAtAtari Posted January 8 Share Posted January 8 (edited) On 1/4/2023 at 3:31 AM, karri said: You need to change the cart/directory.s macro. There is 4 word fields now. The block is not a byte anymore. .macro entry old_off, old_len, new_off, new_block, new_len, new_size, new_addr new_off=old_off+old_len new_block=new_off/__BLOCKSIZE__ new_len=new_size .word new_block .word (new_off & (__BLOCKSIZE__ - 1)) .word new_addr .word new_len .endmacro ; Entry 0 - first executable _MAIN_FILENR=0 entry __STARTOFDIRECTORY__+(__DIRECTORY_END__-__DIRECTORY_START__), 0, mainoff, mainblock, mainlen, __STARTUP_SIZE__+__INIT_SIZE__+__CODE_SIZE__+__RODATA_SIZE__+__DATA_SIZE__, __STARTUP_LOAD__ _HM_FILENR=_MAIN_FILENR+1 entry mainoff, mainlen, hmoff, hmblock, hmlen, __HM_CODE_SIZE__+__HM_RODATA_SIZE__+__HM_DATA_SIZE__, __HM_START__ ... The reason for this is that one of my games I am developing exceeds 512k and the new header works for carts up to 2MB. I also hope to make this change to the official cc65. I went through this too when setting up for my LynxJam game. Also, Karri, you were kind enough to rework my files to allow the create of *.LYX and *.O files. I've been wondering if it would be good to update the template to account for these things. So that people can set up their system and have a bug-free experience from the start. If it seems good to have an updated template, how should we do that? Should I make mine available? Or should Karri or nop90 update theirs that is already available? Edited January 8 by OldAtAtari Quote Link to comment Share on other sites More sharing options...
42bs Posted January 10 Share Posted January 10 (edited) Just setup a github repo and announce it here. Edited January 10 by 42bs 2 Quote Link to comment Share on other sites More sharing options...
OldAtAtari Posted January 10 Share Posted January 10 8 hours ago, 42bs said: Just setup a github repo and announce it here. Thank you, 42bs. I'll get to work on that. I didn't want to step on the toes of these guys who set up the template in the first place. And I also didn't want to create confusion by creating yet another version of the template. There are two or three already. But I'll make it clear that mine is updated and working as of 2023. 1 Quote Link to comment Share on other sites More sharing options...
pwwit1 Posted January 15 Author Share Posted January 15 Thankyou for the responses. Using the new repo worked like a charm Quote Link to comment Share on other sites More sharing options...
