TJ76 Posted July 8, 2023 Share Posted July 8, 2023 On 7/7/2023 at 12:15 AM, TJ76 said: I've recently received my Concerto with Hokey, and experiencing what sounds like may be the same kind of hisses and pops for Ball Blazer and constant noise in background when playing POKEY (Sample) (20140301).a78 (Daisy Bell Test) from atari-7800-roms-ultra on internet archive. Commando sounds ok, albeit with Pokey music a fair bit lower than TIA volume, and reading above about R14 bridge solution, however wondering if I have a bigger problem here? Do you think I may have a defective Hokey also, is this common, or is there anything else I could perhaps test here? I'm using an AV mod as detailed here (7800 PAL revision) , with Pokey audio taken from Right of R33. https://vintagegamingandmore.com/pal/ Thanks for any suggestions. I think I have confirmed the Hokey to be the issue here. I was able to switch with a Pokey from a socketted 800XL I have, and the audio issues went away. So have a bad Hokey I guess? 1 Quote Link to comment Share on other sites More sharing options...
+batari Posted July 9, 2023 Share Posted July 9, 2023 43 minutes ago, TJ76 said: I think I have confirmed the Hokey to be the issue here. I was able to switch with a Pokey from a socketted 800XL I have, and the audio issues went away. So have a bad Hokey I guess? You might have a bad HOKEY. PM me and I can get a replacement to you. Quote Link to comment Share on other sites More sharing options...
