A little OT..What decides the dev number on githubs or the like.
I'm snowed under with things to do, but I always wanted to know what decides a dev number / name and why the odd number jumps between builds?
Take Dreamcast emulator Redream (superb emulator)
Here's 2 days ago name
v1.5.0-1049-gb05282e
And now yesterdays build
v1.5.0-1051-g4ba6a39
Is this decided by a dev rule or just a personal choice?
A lot of emu's just seem to go up in logical jumps ie 4.01, 4.02 etc
Always wondered
These are commit SHAs. With GIT, each commit (a piece of code contributed to the project, if I simplify it) is calculated an SHA (it is a sophisticated checksum). The first few digits of the SHA are then used to identify the commit.
The file names in question indicate that the binaries were compiled from a commit that has the id of gb05282e. This is normal for the development versions, because each development version can be easily tracked to a given commit.
Yes. The other numbers probably are:
vxx.yy.zz-nnnn-
xx=major version
yy=minor version
zz=build version (sometimes...could also be some other kind of internal like a sprint number or whatever)
nnnn- this is probably something related to the build system like a sequentially rising build count or something similar. In my experience not all builds work so it wouldn't necessarily be always sequential.
Edited by danwinslow
Thanks people, I initially thought the Dreamcast one was based on CRC but the G threw me, turns out I wasn't far off. Still not sure about the leaping numbers, although it does make sense if a build was broken so needs to be taken into account for the numbering, hence the number being  X times higher because of failed builds. I just wonder why the dev just ignores the failed one and keeps it in normal sequence.
BUT, thanks people, been wondering about this for a while..
Paul.. In the sunny, but freezing UK..
