centrespot Posted January 26, 2023 Share Posted January 26, 2023 (edited) Hi All I have a Tandy 1000ex and I don't have the boot disk to start using it. Does anyone have a copy of the 1000ex boot disk. Thanks in advance Edited January 26, 2023 by centrespot Quote Link to comment Share on other sites More sharing options...
Michael Kline Posted January 27, 2023 Share Posted January 27, 2023 Use a MSDOS or PCDOS boot disk if you have one. Quote Link to comment Share on other sites More sharing options...
centrespot Posted January 27, 2023 Author Share Posted January 27, 2023 Just now, Michael Kline said: Use a MSDOS or PCDOS boot disk if you have one. I've tried several MSDOS versions and different drive units but nothing works, I read that the EX needs a specific boot disk. Quote Link to comment Share on other sites More sharing options...
Michael Kline Posted January 27, 2023 Share Posted January 27, 2023 Hmm. Too many years have passed for me to remember correctly. If you have a known working disk drive, swap out and see if that's the problem. Quote Link to comment Share on other sites More sharing options...
DistantStar001 Posted January 27, 2023 Share Posted January 27, 2023 (edited) I recently got an ex as well. And like you, I lack the original boot disks. However, I've been using a PC and MS-DOS 3.10 boot disks pretty reliably. What kind of error are you getting? If it's not reading/recognizing your disks, try cleaning your read/write heads with q-tip and some alcohol. You may have done this already, but I've found that my drive can be pretty finicky when it comes to dirt and dust. Edited January 27, 2023 by DistantStar001 Quote Link to comment Share on other sites More sharing options...
Turbo-Torch Posted January 28, 2023 Share Posted January 28, 2023 12 hours ago, centrespot said: I've tried several MSDOS versions and different drive units but nothing works, I read that the EX needs a specific boot disk. No it doesn't. I use every DOS from the included Tandy 2.11 up to MS-DOS 6.22. The OEM 2.11 does include some specific Tandy features, but it's not required. What kind of disks are you using? Are you sure they're DSDD 360K? An HD floppy disk will not work in an EX, even if it's formatted to 360K. Quote Link to comment Share on other sites More sharing options...
centrespot Posted January 28, 2023 Author Share Posted January 28, 2023 (edited) 9 hours ago, Turbo-Torch said: No it doesn't. I use every DOS from the included Tandy 2.11 up to MS-DOS 6.22. The OEM 2.11 does include some specific Tandy features, but it's not required. What kind of disks are you using? Are you sure they're DSDD 360K? An HD floppy disk will not work in an EX, even if it's formatted to 360K. Not sure what format most of the floppy disks are, the labels don't say and I've tried lots of disks. One of them is DSDD 360kb (see photo) I've decided to change the Floppy Drive Controller Chip seeing as it's so cheap and I also have an old PC that I'm looking at installing a 5.25 drive in so that I can test the disks I have. My original post was to see if any one had a working disk so that I could eliminate it from the problems and save time in changing drives, cleaning heads, changing chips etc Edited January 28, 2023 by centrespot Quote Link to comment Share on other sites More sharing options...
centrespot Posted March 12, 2023 Author Share Posted March 12, 2023 (edited) I've bought a working copy of a boot disk from a supplier in the USA and they tested the disk on their 1000EX before posting, I'm still getting "insert system diskette" I also bought another drive unit from eBay listed as "TEAC FD-55BV 360k DS DD 5.25" FDD floppy disc drive" and that also gives the same error message. Will any 5.25 360k FDD work in a Tandy 1000 EX ? Edited March 12, 2023 by centrespot font size error Quote Link to comment Share on other sites More sharing options...
Turbo-Torch Posted March 12, 2023 Share Posted March 12, 2023 (edited) Did you clean the heads (as mentioned by DistantStar) before trying that new disk? If not, there's a good chance the build up will instantly etch and destroy any new disk you insert. The new drive you bought may be fine, but you may have destroyed that new disk if you tried it in the old drive first. Look closely for radial scratches on the disk surface. Also, there's nothing special about the EX drive. It's just a DSDD 360K unit. The 55BV should be fine as long as the jumpers are set correctly. Edited March 12, 2023 by Turbo-Torch Quote Link to comment Share on other sites More sharing options...
centrespot Posted March 12, 2023 Author Share Posted March 12, 2023 (edited) 1 hour ago, Turbo-Torch said: Did you clean the heads (as mentioned by DistantStar) before trying that new disk? If not, there's a good chance the build up will instantly etch and destroy any new disk you insert. The new drive you bought may be fine, but you may have destroyed that new disk if you tried it in the old drive first. Look closely for radial scratches on the disk surface. Also, there's nothing special about the EX drive. It's just a DSDD 360K unit. The 55BV should be fine as long as the jumpers are set correctly. Yes I cleaned the drives several times before trying the disks. No scratches on the disks. What should the jumpers be set to Edited March 12, 2023 by centrespot Quote Link to comment Share on other sites More sharing options...
centrespot Posted March 12, 2023 Author Share Posted March 12, 2023 Incidentally, if the drive is not fitted I get the exact same error message. Quote Link to comment Share on other sites More sharing options...
Turbo-Torch Posted March 12, 2023 Share Posted March 12, 2023 1 hour ago, centrespot said: What should the jumpers be set to https://retrocmp.de/fdd/mitsubi/htandy.pdf Around page 64. 17 minutes ago, centrespot said: Incidentally, if the drive is not fitted I get the exact same error message. Is the drive doing anything? Spinning up, trying to seek tracks, red light on? Quote Link to comment Share on other sites More sharing options...
centrespot Posted March 12, 2023 Author Share Posted March 12, 2023 (edited) 1 hour ago, Turbo-Torch said: Is the drive doing anything? Spinning up, trying to seek tracks, red light on? Yes, it goes through the usual motions and the red light comes on (both the original and the replacement drives). I read somewhere while trying to find a solution that there is a "buffer" between the drive and the controller chip, would that be correct and if so would it cause this issue. Edited March 12, 2023 by centrespot Quote Link to comment Share on other sites More sharing options...
Turbo-Torch Posted March 12, 2023 Share Posted March 12, 2023 1 hour ago, centrespot said: I read somewhere while trying to find a solution that there is a "buffer" between the drive and the controller chip, would that be correct and if so would it cause this issue. It's possibly a controller issue, but I've not heard of that happening. The EX is usually very reliable. Try posting about your problem in the Tandy section of vcfed.org There are at least two guys there who are extremely knowledgeable when it comes to the internal workings of the EX/HX series. If you're new to the forum, you have to be patient as your first 10 posts won't show up right away. Mods have to ok each one which could take up to a day. It's a spam deterrent thing. Quote Link to comment Share on other sites More sharing options...
