Words Fail Posted January 29, 2023 Share Posted January 29, 2023 I would like something to go up by 0.25. Then I need to check later for 1.00, 1.25, 1.50, 1.75, and 2.00. What do I need to dim? dim speed = a.b The whole page on 4.4 and 8.8 confuses me. I think it should say something like this is an example of a few 4.4.. and this is an example of a few 8.8 Quote Link to comment Share on other sites More sharing options...
KevKelley Posted January 29, 2023 Share Posted January 29, 2023 I think I did something similar in trying to make acceleration in one game where I would do something like if joy0right then b=b+25 and then I would do something like if b=100 then a=a+1:b=0 There are probably other ways to do this but it seemed to work for this purpose. 1 Quote Link to comment Share on other sites More sharing options...
bogax Posted January 30, 2023 Share Posted January 30, 2023 (edited) the fractional part is still just a byte it can reperesent 256 values, 0..255 inclusive as a .8 fraction (8 is the number of bits in a byte) a byte is the integer number of 256ths (1/256) 1 = 256 256ths .25 = 256 * .25 = 64 for 0.25 you have two bytes 0 and 64 ie the fractional byte will equal 64 this will be relatively neat in your case because youre looking for multiples of a power of two so eg .25 (a power of 2, 2^-2) is an integer number of 256ths if you want to test for 1.5 it will be 1 and .5 * 256 = 128 if a = 1 && b = 128 then [do something] for non powers of two it gets messier 0.33 is 84.48 256ths ie .33 * 256 = 84.48 and bB rounds it to 84 personally I'd dim it as b.a because the variables are in order in memory and the processor is little endian and expects a 16 bit quantity to be in order in memory with the least byte first but that has nothing to do with what you're doing Edited January 30, 2023 by bogax 2 Quote Link to comment Share on other sites More sharing options...
KevKelley Posted January 30, 2023 Share Posted January 30, 2023 1 hour ago, bogax said: personally I'd dim it as b.a because the variables are in order in memory and the processor is little endian and expects a 16 bit quantity to be in order in memory with the least byte first but that has nothing to do with what you're doing Out of curiosity, would doing this result in some space saved? Less cycles? Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted January 30, 2023 Share Posted January 30, 2023 Never tried the a.b whatever thing as my brain can't handle it. I usually have a main counter that goes up by one each main game loop: main counter = counter + 1 If I want something to happen every four iterations of the main loop I do this: if counter&3 = 0 then goto everyforthdothis That takes the counter that goes from 0 - 255 to something like 0 1 2 3 0 1 2 3 0 1 2 3 .. If you wanted something to happen every other iteration of the main loop you can just check the first bit in the counter since it always flips each time: if counter{0} then goto otherframe 1 Quote Link to comment Share on other sites More sharing options...
