colecovision atarimax incompatibility on the adam
I posted an ADAM compatible ATARIMAX fix a while back and just verified the Spectron hack works with it inserted.
http://adamarchive.org/archive/Technical/ADAM Hardware/John Lundy - AtariMax Ultimate SD Cart - ADAM Workaround.zip
I just tested the T-DOS hack auto fire version and it's working great with my USB adapter with my iBuffalo SNES PAD. Which pad do you have?
Keep in mind that the retroboyz is a direct connect standard joystick with nothing special going on and the USB adapter is doing a lot behind the scenes converting USB to joystick via software and hardware, so there is bound to be some incompatibilities with so many USB joypad variations I had to consider in code.
