Laratari Posted February 10, 2023 Share Posted February 10, 2023 (edited) Hello to everyone! I want to connect my Philips tv 12B611 from 1976 to my atari 2600 from the 70’s that works flawlessly. When I turn the tv on, connect the antenna plug from the atari to the tv, nothing happens. Only “snow” on the screen. I can press some buttons to fix channels (that I can’t change there values) but no one recognises the atari signal. any idea what I can do? There is no channel scanner on the tv. im really frustrated…. Thanks! Edited February 10, 2023 by Laratari Quote Link to comment Share on other sites More sharing options...
alex_79 Posted February 10, 2023 Share Posted February 10, 2023 (edited) It is very important to specify where you are located, as different countries used different TV systems and connections. After a quick search, I found a match for that model and it appears that your TV is PAL, so I assume you're in Europe. 5 hours ago, Laratari said: I can press some buttons to fix channels (that I can’t change there values) but no one recognises the atari signal. any idea what I can do? There is no channel scanner on the tv. The front buttons are presets. You can tune each of them to a specific channel using the trimmers and switches on the side of the TV. The white switches below each trimmer select the band. If you're in mainland Europe, your console should be in "PAL-B" standard and output on channel VHF 3 or 4. Set the white switch to band "I" and tune the trimmer (with the console powered on and a cartridge inserted) corresponding to the preset you're using until you find the channel. If you're in UK or Ireland, then your console should be in "PAL-I" standard and outputs on channel UHF 36. In that case set the white switch to "UHF" band. Edited February 10, 2023 by alex_79 2 Quote Link to comment Share on other sites More sharing options...
Laratari Posted February 10, 2023 Author Share Posted February 10, 2023 Wow Alex! Thanks so much! I didn’t new that the tuning was there…( I bought today the Tv). im located in Israel so I’m in pal system, don’t know exactly if it b or not. will try tomorrow morning and let you know of course. thanks again! Quote Link to comment Share on other sites More sharing options...
Laratari Posted February 11, 2023 Author Share Posted February 11, 2023 Update: thanks to Alex, I managed with some tuning and cleaning to achieve nice picture in this 1976 to and played natural. thanks again! 3 Quote Link to comment Share on other sites More sharing options...
