zork Posted February 18, 2023 Share Posted February 18, 2023 Quick question - does PAL 130XE would display color on 1084S NTSC monitor. Apparently it can work in both modes (with Amiga), but what about PAL Atari 8-bit? Quote Link to comment Share on other sites More sharing options...
zork Posted February 19, 2023 Author Share Posted February 19, 2023 answering my own thread -- it won't work in color (only in b&w). Quote Link to comment Share on other sites More sharing options...
Rybags Posted February 19, 2023 Share Posted February 19, 2023 It does - but stock 130XE only gives chroma+luma, not RGB. You also might like to split mono audio to 2 outputs to feed each speaker. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted February 19, 2023 Share Posted February 19, 2023 As Rybags said - PAL RGB will have colour, but the composite or luma/chroma will not. Quote Link to comment Share on other sites More sharing options...
zork Posted February 19, 2023 Author Share Posted February 19, 2023 right, I noticed that. Can the stock model output RGB though at all? (with some converter etc.) Quote Link to comment Share on other sites More sharing options...
zork Posted February 19, 2023 Author Share Posted February 19, 2023 After some research it appears you need VBXE to output RGB. In conclusion: PAL Atari and NTSC monitor or vice versa will not work with stock s-video/composite. Quote Link to comment Share on other sites More sharing options...
mimo Posted February 19, 2023 Share Posted February 19, 2023 22 minutes ago, zork said: After some research it appears you need VBXE to output RGB. In conclusion: PAL Atari and NTSC monitor or vice versa will not work with stock s-video/composite. Or Sophia 2 Quote Link to comment Share on other sites More sharing options...
tjlazer Posted February 19, 2023 Share Posted February 19, 2023 Yeah sadly it doesn't but RGB singlas do work as such on the Amiga. I did see that my Commodore 64 PAL does show color when using a S-Video cable on my large screen TV. Quote Link to comment Share on other sites More sharing options...
Rybags Posted February 19, 2023 Share Posted February 19, 2023 Stock composite has colour but does 1084 support that? Sophia 2 does RGB but it uses scan-doubling so probably won't work on 16 KHz monitors like 1084. But regardless, any 130XE should provide the needed colour signal. Quote Link to comment Share on other sites More sharing options...
