Ecernosoft Posted February 18, 2023 Share Posted February 18, 2023 Just wanted to show this... Sprite_scaling (3).a26 Sprite_scaling (1).dasm Very simple, but it works. Enjoy. Sprite_scaling (3).a26 2 Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted February 18, 2023 Author Share Posted February 18, 2023 (edited) By the way, is there a way to get around the "Jumping"? Main reason is because in my future games, I want to have "ECERNOSOFT" appear using vertical sprite scaling, thought it'd be cool. Some more tests..... Sprite_scaling (4).a26; Seizure warning!!! Sprite_scaling (2).dasm; A little better? This is source code though. Sprite_scaling (3).dasm Sprite_scaling (5).a26; This and the above are both the same but this is much better Sprite_scaling (2).dasm Edited February 18, 2023 by Ecernosoft Quote Link to comment Share on other sites More sharing options...
bigmessowires Posted February 19, 2023 Share Posted February 19, 2023 What kind of effect are you trying to create? I looked through the code, but couldn't really understand what's intended. Are you hoping to smoothly scale the text in the vertical dimension to any arbitrary height? I might suggest keeping a vertical coordinate in 8.8 fixed point. On every scan line, use the integer part to index into your logo data, then add a fractional delta value. That should enable you to get smooth scaling without jumpiness. Here's some untested code: lda #42 ; change this value for different scaling sta Vpos_scale lda #0 sta Vpos_lo sta Vpos_hi ldy #192 Count ldx Vpos_hi lda Logo,x sta PF1 sta PF2 lda Vpos_lo clc adc Vpos_scale sta Vpos_lo lda Vpos_hi adc #0 sta Vpos_hi dey sta WSYNC bne Count 3 Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted February 19, 2023 Author Share Posted February 19, 2023 (edited) 3 hours ago, bigmessowires said: What kind of effect are you trying to create? I looked through the code, but couldn't really understand what's intended. Are you hoping to smoothly scale the text in the vertical dimension to any arbitrary height? I might suggest keeping a vertical coordinate in 8.8 fixed point. On every scan line, use the integer part to index into your logo data, then add a fractional delta value. That should enable you to get smooth scaling without jumpiness. Here's some untested code: lda #42 ; change this value for different scaling sta Vpos_scale lda #0 sta Vpos_lo sta Vpos_hi ldy #192 Count ldx Vpos_hi lda Logo,x sta PF1 sta PF2 lda Vpos_lo clc adc Vpos_scale sta Vpos_lo lda Vpos_hi adc #0 sta Vpos_hi dey sta WSYNC bne Count Yes!! That is what I'm trying to do. Like, in NEO GEO how the logo for it sort of "Stretches into existance". That's what I'm trying to do. Edit: *tests code* Thanks! (Part of this is because as a fun little thing, I thought I'd design my own video chip, and one of the things I'd like would be vertical scaling, and possibly horizontal too.) Edited February 19, 2023 by Ecernosoft Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted February 19, 2023 Author Share Posted February 19, 2023 (edited) Honestly I might be able to have a kernal with scaling for the background thanks to this! Big thanks to @splendidnut! Though how exactly does this work? Edit: and will this work on the 5200/8bit using the vertical scroll register? Edited February 19, 2023 by Ecernosoft Quote Link to comment Share on other sites More sharing options...
+splendidnut Posted February 19, 2023 Share Posted February 19, 2023 20 minutes ago, Ecernosoft said: Big thanks to @splendidnut! Not sure what I did... It was @bigmessowires who provided something for you to try. I was in the process of writing a response when he beat me to it. 1 Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted February 19, 2023 Author Share Posted February 19, 2023 (edited) 3 hours ago, splendidnut said: Not sure what I did... It was @bigmessowires who provided something for you to try. I was in the process of writing a response when he beat me to it. Lol oops! Big thanks to @bigmessowires! Lol oops. Edit: I added the full logo........ unfortunately since the different sections of the logo are stored sequentially it looks sort of garbled. Sprite_scaling (4).dasm; Source code Sprite_scaling (6).a26; hmmm... I wonder what this does. Edit 2: I'm also going to port it to the 5200 and hopefully the 7800. 5200 won't be that hard as I can just use the 4 players to act "like" PF1, PF2, PF1', and PF2'. 7800 unfortunately doesn't use players or the playfeild so I'll have to use CHARBASE and that might require completely new code. Edited February 19, 2023 by Ecernosoft Quote Link to comment Share on other sites More sharing options...
bigmessowires Posted February 19, 2023 Share Posted February 19, 2023 The example code I posted works, but the final height of the logo is inversely proportional to Vpos_scale. So if you change Vpos_scale linearly like in my example, the logo height changes non-linearly, and it looks a little strange. Here's some code that corrects for this by changing the logo height linearly, and using a look-up table to determine the right Vpos_scale value needed to get the desired height. The logo doesn't scale quite as smoothly at large logo heights though. I think you'd need to go to 8.16 fixed point format to get totally smooth scaling using this technique. vscale.dasm 1 Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted February 19, 2023 Author Share Posted February 19, 2023 3 hours ago, bigmessowires said: The example code I posted works, but the final height of the logo is inversely proportional to Vpos_scale. So if you change Vpos_scale linearly like in my example, the logo height changes non-linearly, and it looks a little strange. Here's some code that corrects for this by changing the logo height linearly, and using a look-up table to determine the right Vpos_scale value needed to get the desired height. The logo doesn't scale quite as smoothly at large logo heights though. I think you'd need to go to 8.16 fixed point format to get totally smooth scaling using this technique. vscale.dasm 3.58 kB · 0 downloads Honestly all I do is decrement the scale variable and it looks mostly fine. sure there's still a bounce but it's nowhere near as bad as my version which is full of bouning. Quote Link to comment Share on other sites More sharing options...
bigmessowires Posted February 19, 2023 Share Posted February 19, 2023 47 minutes ago, Ecernosoft said: Though how exactly does this work? Are you familiar with fixed point numbers? This method is using a two-byte fixed point counter (Vpos_hi and Vpos_lo) to step through the lines of the logo. As you've found, you can't use an integer step size, or else the final logo height will always be some multiple of the number of lines in your logo, and you can't get smooth scaling. You could extend this technique to a three-byte fixed point counter with one integer byte and two fractional bytes, and a two-byte lookup table to match, and it should be 100 percent smooth. If you have enough CPU time, you could also replace the lookup table with a software division subroutine. 1 Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted February 19, 2023 Author Share Posted February 19, 2023 3 hours ago, bigmessowires said: Are you familiar with fixed point numbers? This method is using a two-byte fixed point counter (Vpos_hi and Vpos_lo) to step through the lines of the logo. As you've found, you can't use an integer step size, or else the final logo height will always be some multiple of the number of lines in your logo, and you can't get smooth scaling. You could extend this technique to a three-byte fixed point counter with one integer byte and two fractional bytes, and a two-byte lookup table to match, and it should be 100 percent smooth. If you have enough CPU time, you could also replace the lookup table with a software division subroutine. Well..... kinda. I'm not the best with it though. Though seriously. I'm amazed. Keep up the good work. (I'm also going to port it to the 5200 and 7800!) Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted February 19, 2023 Author Share Posted February 19, 2023 Atari 5200 version: Scaling.a Scaling-atari8-5200.bin Unfortunately the graphics haven't been corrected. Quote Link to comment Share on other sites More sharing options...
JetSetIlly Posted February 19, 2023 Share Posted February 19, 2023 Nice. It looks similar to the effect on the title screen of Assembloids. 1 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted February 20, 2023 Share Posted February 20, 2023 The title screens of SWOOPS! and Ixion do something similar. Quote Link to comment Share on other sites More sharing options...
