+9640News Posted February 20 Share Posted February 20 Stuart Conner's Web Browser for the TI-99/4A and MDOS ===================================================== MDOS Version: 9.4g Assembly Date 2/18/2023 Stuart released his web browser for the TI-99/4A and TIPI over a year ago. I made an inquiry with Stuart about the possibility of converting his web browser source code to work with the Geneve 9640. Stuart had previously shared an earlier version of his soure code for a RS232 telnet based access. When he had posted he was working on a TIPI version, I waited until I had free time to work on the project. Stuart was gracious and was willing to share his source code. After 4 weeks of reviewing over 4,000 lines of code, I have to my knowledge, converted his program to run under MDOS. To give an idea of what was required, the easiest was modifying the video routines to use the Geneve's video port addresses in MDOS. Next, was modifying the KSCAN (Keyscan) routines to use the MDOS KEYBOARD XOP. All keyboard mapping for the TI-99/4A required modification to pass into variable labels I added. The next modification and updates required adding memory mapping and then fragmenting the code around the TIPI interface. With the TIPI interface, use of the actual code in the TIPI DSR while in MDOS mode can not be used. Rather, as had been previously learned when developing code for MDOS to work with the Geneve, the send and receive message routines needed to be in the MDOS code itself rather than running the code from the eprom directly. This is not clearly understood why, but is a requirement. Finally, the most complex section of code needing to be modified was the DSR routines. With the TI-99/4A, the PABS are written to VDP prior to calling the DSRLNK code. With the Geneve 9640 in MDOS mode, PABS are in CPU RAM. While this may not seem all too complex, to accomplish what Stuart needed with the limited memory of the TI-99/4A, the use of overlapping PABS for several files he uses in the code required time to convert. With the browser, Stuart maintains an equivalent character definition in the FONTS file at TIP1.BROWSER. I have embedded the contents of this file into the MDOS version as each page update would result in reloading the file as the browser tags allow character redefinition for various graphics. The COOKIES file maintains definition credentials for use such as on the myti99.com website. The FAVS file maintains a list of favorites accessible from a keyboard keypress for a webpage you can define. The most complex file was the LINKS file. This file maintains a list of records on the currently displayed page. As html tags such as input and submit process, these records for the content contained in the LINKS file is modified. It was truly an ingenious way of handling complex code. Stuart deserves a lot of credit for his accomplishment. Requirements ============ The MDOS version will use a USB TIPI mouse. If a USB TIPI mouse is not available, then one may use the keyboard. The joystick routines were removed following the conversion to the MDOS version. . On the TIPI, you must have a folder named BROWSER. You can either copy the program image files to that folder and keep everything contained, or place the browser files at another location. You will need Stuart's files he distributed including COOKIES, FAVS, LINKS, and FONTS to be installed in the same folder. Stuart's original INTERNET file, an EA#3 file, can also be run on the Geneve in GPL mode using the ROMPAGE. Future Updates. ============== I have an idea or two about future updates, however I do not know if Stuart will continue development of the TI-99/4A version. I am very hesitant to utilize the higher graphic mode environments of the 9938 video chip on the Geneve. I say this because this would likely render incompatibilies with the TI-99/4A webpage displays. Recognition =========== Again, I would like to recognize Stuart for his accomplishment and trust to allow me to convert his program to be used in MDOS mode on the Geneve. While I believe I created no bugs, thus far, everything tested responds as predicted on the Geneve. If there is a reproducible issue found where code does not behave the same between Stuart's release for the TI-99/4A and the MDOS version, please let me know. Beery Miller Beery@USWingNuts.com 9640News on Atariage 2/19/2023 MDOS Browser 2023-02-18.zip 10 Quote Link to comment Share on other sites More sharing options...
