Grig Posted February 21, 2023 Share Posted February 21, 2023 Is there any kind of harmony or uno cart that will work on an unmodified 400? or is the SDrive-Max the best option for loading the under 16k programs? (or will it even work on the 400?) Thanks! 1 Quote Link to comment Share on other sites More sharing options...
zylon Posted February 21, 2023 Share Posted February 21, 2023 4 hours ago, Grig said: Is there any kind of harmony or uno cart that will work on an unmodified 400? or is the SDrive-Max the best option for loading the under 16k programs? (or will it even work on the 400?) Thanks! the Atarimax flashcart/ programmer setup works well on 400. Sdrive max runs great for me, but I upgraded to 48k before trying. Some other carts out there might run, but I can verify that MyIdeII, and Unocart would not, even after memory upgrade. Supposedly, an Unocart will run on a 48k 400, if the Atari style RAM upgrade is used, but I've not tried. AVG Cart is one I hear alot about, and you might look into. 1 Quote Link to comment Share on other sites More sharing options...
zylon Posted February 21, 2023 Share Posted February 21, 2023 I just had a thread exploring the 400 this week, so fresh info given by many. Quote Link to comment Share on other sites More sharing options...
marauder666 Posted February 21, 2023 Share Posted February 21, 2023 AVG cart technically does work, but as I found out when a 400 is fully assembled, its too tight in the cart slot, due to the shielding. So not really working. Quote Link to comment Share on other sites More sharing options...
Sinjinhawke Posted February 21, 2023 Share Posted February 21, 2023 I only have an SDRIVE2, Fujinet 5 and SIDE3. None of them worked in my 16k 400 until I upgraded to 48K. SIDE3 was tested while machine was disassembled as it does not fit in the cart port. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted February 21, 2023 Share Posted February 21, 2023 One screw unburdens the PCB just transplant it into a better shell. 1 Quote Link to comment Share on other sites More sharing options...
