Pretty pattern
Vorticon
So I came across this video by 8-bit Show and Tell on Youtube and I thought it would be interesting to recreate that on the TI, so I did :) I could not get the pattern to work initially, until I figured out that the line length had to be Odd, not Even, for reasons that are unclear to me. That said, I'm not terribly happy with my code, and I was wondering if there is a way to optimize it somehow...
10 CALL CLEAR :: RANDOMIZE
20 CALL SCREEN(10)
30 CALL COLOR(1,7,10,2,9,10)
40 CALL CHAR(33,"FF7F3F1F0F07030180C0E0F0F8FCFEFF")
50 CALL CHAR(40,"FFFEFCF8F0E0C0800103070F1F3F7FFF")
60 B=B=0
70 FOR I=1 TO 27 :: B=B=0
80 Z=INT(RND+0.5)
90 IF Z=0 THEN CH=33 ELSE CH=40
100 IF B=-1 THEN IF Z=0 THEN CH=34 ELSE CH=41
110 IF I=27 THEN PRINT CHR$(CH)ELSE PRINT CHR$(CH);
120 NEXT I
130 GOTO 70
  • Like 5
I was intrigued too and had a go with green instead of red 🙂:
100 CALL CLEAR
110 CALL SCREEN(3)
120 CALL COLOR(9,4,13)
130 CALL CHAR(96,"FFFEFCF8F0E0C080")
140 CALL CHAR(97,"0103070F1F3F7FFF")
160 CALL CHAR(98,"80C0E0F0F8FCFEFF")
165 CALL CHAR(99,"FF7F3F1F0F070301")
170 RV=INT(RND*4)
180 PRINT CHR$(96+RV);
190 GOTO 170
Definitely needs work ;-)
Edited by JJB
clatification
Give this a go.
10 CALL CLEAR :: RANDOMIZE :: CALL SCREEN(10):: CALL COLOR(1,7,10,2,9,10)
20 CALL CHAR(33,"FF7F3F1F0F07030180C0E0F0F8FCFEFF",40,"FFFEFCF8F0E0C0800103070F1F3F7FFF")
30 FOR I=1 TO 27 :: B=B=0 :: PRINT CHR$(34+INT(RND+.5)*7+B);:: NEXT I :: PRINT :: GOTO 30
15 minutes ago, OLD CS1 said:
Give this a go.
Oh, and to reverse the effect of B, change line 30:
30 FOR I=1 TO 27 :: B=B=0 :: PRINT CHR$(33+INT(RND+.5)*7-B);:: NEXT I :: PRINT :: GOTO 30
Lastly, you can move B=B=0 to between the PRINT and NEXT statements to have it start at 0 rather than -1.
16 minutes ago, OLD CS1 said:
Give this a go.
Yes that looks great. Shame the TI doesn't have several shades of gray ;-)
1 hour ago, Retrospect said:
@oddemann for example, this particular line won't go down too well with the compiler, it would have to be amended somehow.
I had used RND*2 before, but I am not certain how RND returns.  @senior_falcon has some details on the best way to use RND when compiled.
I must say those patterns are very pretty and would make a good "transition" effect between levels on an arcade game.  Not that I want to derail the thread or anything but still, they're nice. :)
2 hours ago, OLD CS1 said:
Also, this is from my back-library of schtuff.
5 RANDOMIZE
10 PRINT CHR$(47+INT(RND*2)*45);:: GOTO 10
Surprisingly, a little slower than its TI BASIC equivalent.
XB random number generator sucks from what Rich has seen. Could be that.
13 hours ago, JJB said:
Cool that we both had the same idea of replacing the C64 inversion capability with a char definition.
Yeah that was the fastest way to simulate inversion. One could write a routine to do that, but it would have been way too slow.
14 hours ago, OLD CS1 said:
Give this a go.
That's what I'm talking about!
B=B=0   I don't understand the purpose of this? It sets B=0 and I see no place where B is ever changed
RND+.5 will be a value from .5 to 1.4999.....
so INT(RND+.5) will be 0 or 1 with an equal chance of either one.
so INT(RND+.5)*7 will be either 0 or 7
You could replace that with PRINT CHR$(34+INT(RND*2)*7); and since B=0 I left it out.
And with those changes I think this could be compiled.
Edited by senior_falcon
That is not what happens. B is set to -1 (TRUE) if B=0 going into the expression or 0 (FALSE), otherwise. The first '=' is an assignment operator and the second '=' is a relational operator. The expression is treated the same as though it were stated
B=(B=0)
...lee
B=(B=0)
...lee
You are right! I thought that is what would happen and tested this in the immediate mode:
B=B=0
PRINT B
and it prints 0
It must be that B was set to some value other than zero, because if you enter
B=0
B=B=0
PRINT B
then -1 is printed.
And of course, the program 10 B=B=0::PRINT B
will print -1 as you say.
B=B=0
PRINT B
and it prints 0
B=0
B=B=0
PRINT B
then -1 is printed.
Yeah, in Walid’s program, B will alternate between 0 and -1 as the loop containing it executes.
...lee
...lee
I changed the program to see what was going on in B and it was just -1 0 over and over and over?
30 FOR I=1 TO 27 :: B=B=0 :: S$=S$&STR$(B):: PRINT CHR$(34+INT(RND+.5)*7+B);:: NEXT I :: PRINT :: GOTO 30
Yea I know it crashes with string full but just FCTN 4 and type PRINT S$ to see result.
i'm guessing the B=(B=0) is getting out of sync when the line is even. I bet if you added B=(B=0) after NEXT I it would work properly with an even line length. (and improperly with an odd line length)
The line length is controlled by I, hence 27 characters and thus odd.
