42bs Posted February 23, 2023 Share Posted February 23, 2023 GPU/DSP only version, direct boot. https://github.com/42Bastian/JaguarDemos/tree/main/yarc_reloaded cube.j64 2 Quote Link to comment Share on other sites More sharing options...
alucardX Posted February 25, 2023 Share Posted February 25, 2023 So you've gone through and moved everything over to the RISCs? In your experience in doing this, what benefits do you see? Quote Link to comment Share on other sites More sharing options...
42bs Posted February 25, 2023 Author Share Posted February 25, 2023 2 hours ago, alucardX said: So you've gone through and moved everything over to the RISCs? In your experience in doing this, what benefits do you see? I went into extrem, esp. because I wanted to boot directly from BIOS so, 68k was no option, or at least using the 68k would be a bit more difficult. But I think, using the 68k to do the nasty things like video init and debug output is ok. So it sits on a STOP #$2000 and is woken up by the GPU only to print some debug info is the best way. 1 Quote Link to comment Share on other sites More sharing options...
